.NET
Marshal.GetActiveObject not working in Autocad 2024
5 REPLIES 5
josborneW959Y
481 Views, 5 Replies
Looks like this code doesn't work in Autocad 2024.
*Moderator Edit* Post your code in a code window.
// Get a running instance of AutoCAD
  try
  {      acAppComObj = (AcadApplication)Marshal.GetActiveObject(strProgId);
  catch // An error occurs if no instance is running
As referred in
https://help.autodesk.com/view/OARX/2024/ESP/?guid=GUID-C8C65D7A-EC3A-42D8-BF02-4B13C2EA1A4B
It works for older versions of Autocad but not for Autocad 2024.
Am I missing something? Any help?
5 REPLIES 5
Ed.Jobe
in reply to: josborneW959Y
Are you sure that you are passing the correct value of strProgId?
From Help:
Note: The ProgID for COM application access to AutoCAD 2024 is AutoCAD.Application.24.3.
Ed
How to post your code.
josborneW959Y
in reply to: Ed.Jobe
Super sure! My code is almost same as Autodesk sample. It doesn't work... any tip?
I'm running it from inside Autocad by the way.
Edited:  Also this code was created around version 2017/18, and worked perfectly fine in old Autocad versions.
Ed.Jobe
The call should look like
  {      acAppComObj = (AcadApplication)Marshal.GetActiveObject("AutoCAD.Application.24.3");
Why? You only need that if your code is running out-of-process. If your code is running inside acad, then you already know that the program is running. Just use the Application object or the AcadApplication object if you are using the COM api.
using acApp = Autodesk.AutoCAD.ApplicationServices.Application
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
Ed
kdub_nz
 . . . and it never hurts if you name the variables for COM objects so they're easily identifiable and distinguishable.
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
josborneW959Y
It worked... I forgot to update references, when I did old GetActiveObject also worked. My fault...
Thanks!!
Forma Design Contest
