.NET
Unable access AutoCAD drawing file content - acdbmgd.dll
5 REPLIES 5
patelvp8921
342 Views, 5 Replies
Trying to access AutoCAD drawing file content using following runtime initialization.
Autodesk.AutoCAD.RuntimeSystem.Initialize(HostApplicationServices,1033).
It is not throwing any error but the HostApplicationServices object is not initialized.
Application Type - VB.NET WinForm - 4.8 Framework.
Tried with acdbmgd.dll from AutoCAD 2024 installation as well as Object ARX SDK.
5 REPLIES 5
Ed.Jobe
in reply to: patelvp8921
You cannot use the managed .NET api from a standalone exe. You can only use the COM api. Use the GetObject method to access the application. See this thread.
Ed
How to post your code.
patelvp8921
in reply to: Ed.Jobe
The same application was working with AutoCAD 2020 when tested last time. Just updated references to 2024 and it is not working now.
If this a managed extension DLL that you're loading into AutoCAD, or a standalone RealDwg host application executable?
It is a standalone executable.
Are you using the RealDWG SDK, or are you just trying to load AcDbxx.dll into a standalone executable?
Forma Design Contest
