.NET
Find all blocks on a certain layer
1 REPLY 1
981 Views, 1 Reply
I want to find all the blocks, lines, circles etc. on a layer. I have found two possible way of doing this but I am having problems with  them both. My first method was from here where I used something like:
        public static void LayerInfoGrab(string LayerName, int LayerType)
            //link to the current document and databases
            Document Doc = Application.DocumentManager.MdiActiveDocument;
            Database db = Doc.Database;
            Editor ed = Doc.Editor;
            using (Transaction Trans = db.TransactionManager.StartTransaction())
                //Open the block table open for read
                BlockTable Btr = Trans.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                //Open the model space database for read
                BlockTableRecord BtrModel = Trans.GetObject(Btr[BlockTableRecord.ModelSpace],OpenMode.ForRead) as BlockTableRecord;
                //Step through the objects and find any on the layer we want
                foreach (object SPAobject in BtrModel)
                    //Test the object for block type
                    if (SPAobject is Line)
                    if (SPAobject is Circle)
But (SPAobject is Block) does not work. My second method is the selection filter but I don't have a name for the block, but I do want all the blocks on the layer. I didn't know if I could use something like "*" instead of the block name?
1 REPLY 1
_gile
Your question is not clear. Do you want to get all blocks (more accurately block references) on a layer or all entities (including bloc references, lines, circles, etc.) ?
To get all model space entities on a specified layer:
Iteratiing the model space
        static ObjectIdCollection GetByLayer(string layerName)
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ids = new ObjectIdCollection();
            using (var tr = db.TransactionManager.StartOpenCloseTransaction())
                var ms = (BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead);
                foreach (ObjectId id in ms)
                    var ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
                    if (ent.Layer.Equals(layerName, StringComparison.CurrentCultureIgnoreCase))
                        ids.Add(id);
                tr.Commit();
            return ids;
Using a selection filter
        static ObjectIdCollection SelectByLayer (string layerName)
            var ed = Application.DocumentManager.MdiActiveDocument.Editor;
            var filter = new SelectionFilter(new[]
                new TypedValue(8, layerName),   // layer
                new TypedValue(410, "Model")   // model space
            var psr = ed.SelectAll(filter);
            if (psr.Status == PromptStatus.OK)
                return new ObjectIdCollection(psr.Value.GetObjectIds());
            else
                return new ObjectIdCollection();
To get all model space block references on a specified layer:
        static ObjectIdCollection GetBlocksByLayer(string layerName)
                    if (id.ObjectClass.DxfName == "INSERT")
                            ids.Add(id);
                tr.Commit();
            return ids;
        static ObjectIdCollection SelectBlocksByLayer(string layerName)
                new TypedValue(0, "INSERT"),    // block reference
            else
Gilles Chanteau
GileCAD
GitHub
Forma Design Contest
AutoCAD Beta
