I want to find all the blocks, lines, circles etc. on a layer. I have found two possible way of doing this but I am having problems with them both. My first method was from here where I used something like:
public static void LayerInfoGrab(string LayerName, int LayerType) { //link to the current document and databases Document Doc = Application.DocumentManager.MdiActiveDocument; Database db = Doc.Database; Editor ed = Doc.Editor; using (Transaction Trans = db.TransactionManager.StartTransaction()) { //Open the block table open for read BlockTable Btr = Trans.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable; //Open the model space database for read BlockTableRecord BtrModel = Trans.GetObject(Btr[BlockTableRecord.ModelSpace],OpenMode.ForRead) as BlockTableRecord; //Step through the objects and find any on the layer we want foreach (object SPAobject in BtrModel) { //Test the object for block type if (SPAobject is Line) { } if (SPAobject is Circle)
But (SPAobject is Block) does not work. My second method is the selection filter but I don't have a name for the block, but I do want all the blocks on the layer. I didn't know if I could use something like "*" instead of the block name?
Solved by _gile. Go to Solution.
Your question is not clear. Do you want to get all blocks (more accurately block references) on a layer or all entities (including bloc references, lines, circles, etc.) ?
To get all model space entities on a specified layer:
Iteratiing the model space
static ObjectIdCollection GetByLayer(string layerName) { var doc = Application.DocumentManager.MdiActiveDocument; var db = doc.Database; var ids = new ObjectIdCollection(); using (var tr = db.TransactionManager.StartOpenCloseTransaction()) { var ms = (BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead); foreach (ObjectId id in ms) { var ent = (Entity)tr.GetObject(id, OpenMode.ForRead); if (ent.Layer.Equals(layerName, StringComparison.CurrentCultureIgnoreCase)) ids.Add(id); } tr.Commit(); } return ids; }
Using a selection filter
static ObjectIdCollection SelectByLayer (string layerName) { var ed = Application.DocumentManager.MdiActiveDocument.Editor; var filter = new SelectionFilter(new[] { new TypedValue(8, layerName), // layer new TypedValue(410, "Model") // model space }); var psr = ed.SelectAll(filter); if (psr.Status == PromptStatus.OK) return new ObjectIdCollection(psr.Value.GetObjectIds()); else return new ObjectIdCollection(); }
To get all model space block references on a specified layer:
static ObjectIdCollection GetBlocksByLayer(string layerName) { var doc = Application.DocumentManager.MdiActiveDocument; var db = doc.Database; var ids = new ObjectIdCollection(); using (var tr = db.TransactionManager.StartOpenCloseTransaction()) { var ms = (BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead); foreach (ObjectId id in ms) { if (id.ObjectClass.DxfName == "INSERT") { var ent = (Entity)tr.GetObject(id, OpenMode.ForRead); if (ent.Layer.Equals(layerName, StringComparison.CurrentCultureIgnoreCase)) ids.Add(id); } } tr.Commit(); } return ids; }
static ObjectIdCollection SelectBlocksByLayer(string layerName) { var ed = Application.DocumentManager.MdiActiveDocument.Editor; var filter = new SelectionFilter(new[] { new TypedValue(0, "INSERT"), // block reference new TypedValue(8, layerName), // layer new TypedValue(410, "Model") // model space }); var psr = ed.SelectAll(filter); if (psr.Status == PromptStatus.OK) return new ObjectIdCollection(psr.Value.GetObjectIds()); else return new ObjectIdCollection(); }
