.NET
Delete a block by name then purge all .net C#
3 REPLIES 3
4116 Views, 3 Replies
So I have a situation where I have a known block, that I need to delete.
The problem is, once I delete it...it seems to take about three purges to clear all of the purged data.
I can type in Purge and then have to purge all three times.
What is the simplest way to simply delete a known block, and purge all of the data with one shot.
I then plan on reinserting the known block using a string to execute.
I am using code to update 40+ sheets in a directory.  The current code is using Database db = new Database(false,false).
Will simply saying db.Purge work in this case?  For the purge portion of this?
3 REPLIES 3
foreach (string fileName in fileNames)
if (fileName.EndsWith(
".dwg",
StringComparison.CurrentCultureIgnoreCase
Database db = new Database(false, false);
using (db)
try
ed.WriteMessage(
"\n\nProcessing file: " + fileName
db.ReadDwgFile(fileName, FileShare.ReadWrite, false, "");
int attributesChanged = UpdateAttributesInDatabase(db, blockName, attbName, attbValue, attOriginator, attOriginatorValue);
// Display the results
ed.WriteMessage("\nUpdated {0} instance{1} of " + "attribute {2}.", attributesChanged, attributesChanged == 1 ? "" : "s", attbName);
// Only save if we changed something
if (attributesChanged > 0)
db.SaveAs(
fileName,
DwgVersion.Current
saved++;
processed++;
catch (System.Exception ex)
ed.WriteMessage("\nProblem processing file: {0} - \"{1}\"", fileName, ex.Message);
problem++;
ed.WriteMessage("\n\nSuccessfully processed {0} files, of which {1} had " + "attributes to update and an additional {2} had errors " + "during reading/processing.", processed, saved, problem);
private int UpdateAttributesInDatabase(Database db, string blockName, string attbName, string attbValue, string attOriginator, string attOriginatorValue)
Document doc =
Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
// Get the IDs of the spaces we want to process
// and simply call a function to process each
ObjectId msId, psId;
Transaction tr =
db.TransactionManager.StartTransaction();
using (tr)
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
msId = bt[BlockTableRecord.ModelSpace];
psId = bt[BlockTableRecord.PaperSpace];
// Not needed, but quicker than aborting
tr.Commit();
int msCount = UpdateAttributesInBlock(msId, blockName, attbName, attbValue);
int psCount = UpdateAttributesInBlock(psId, blockName, attbName, attbValue);
return msCount + psCount;
private int UpdateAttributesInBlock(ObjectId btrId, string blockName, string attbName, string attbValue)
// Will return the number of attributes modified
int changedCount = 0;
Document doc =
Database db = doc.Database;
Transaction tr =
doc.TransactionManager.StartTransaction();
using (tr)
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(btrId, OpenMode.ForRead);
// Test each entity in the container...
foreach (ObjectId entId in btr)
Entity ent = tr.GetObject(entId, OpenMode.ForRead)
as Entity;
if (ent != null)
BlockReference br = ent as BlockReference;
if (br != null)
BlockTableRecord bd = (BlockTableRecord)tr.GetObject(br.BlockTableRecord, OpenMode.ForRead);
// ... to see whether it's a block with
// the name we're after
if (bd.Name.ToUpper() == blockName)
// Check each of the attributes...
foreach (
ObjectId arId in br.AttributeCollection
DBObject obj = tr.GetObject(arId, OpenMode.ForRead);
AttributeReference ar = obj as AttributeReference;
if (ar != null)
// ... to see whether it has
// the tag we're after
if (ar.Tag.ToUpper() == attbName)
// If so, update the value
// and increment the counter
ar.UpgradeOpen();
ar.TextString = attbValue;
ar.DowngradeOpen();
changedCount++;
// Recurse for nested blocks
changedCount += UpdateAttributesInBlock(br.BlockTableRecord, blockName, attbName, attbValue);
tr.Commit();
return changedCount;
Ok I figured out how to purge all via command line.  I will just need to run it three times.
-PU
all
n
Courtesy of this post:
https://forums.autodesk.com/t5/autocad-forum/deleting-block-names-in-the-block-file-list-in-2016/td-...
I have now found out how to delete a block via .net programming.
https://forums.autodesk.com/t5/net/delete-block-from-autocad-drawing/td-p/5533072
A simple copy and paste and BOOM, done. 🙂
Technology Administrators
