Hello everyone,
i need to delete a block from my autocad drawing.
Is there any way i can search for a block in the drawing(by its name for example-'Terminal1') and delete it from the drawing??
I am able to check if a certain block name (ex-terminal1) is present in the current drawing or not,but i do not know how to remove that portion from the drawing.If anyone can give a solution it will be of great help.
Regards
Aaditya
Solved by SENL1362. Go to Solution.
This might help you to get started. Don't ever erase a Block when there are references to prevent drawing corruption.
[CommandMethod("TestEraseBlk")] public void TestEraseBlk() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; var blkName = "Terminal1"; try { var blkId = GetBlkId(db, blkName); if (blkId.IsNull) throw new System.Exception(string.Format("\n Block not found: {0}", blkName)); if (!EraseBlkRefs(blkId)) throw new System.Exception(string.Format("\n Failed to Erase BlockReferences for: {0}", blkName)); if (!EraseBlk(blkId)) throw new System.Exception(string.Format("\n Failed to Erase Block: {0}", blkName)); ed.WriteMessage("\n Block Erased: {0}", blkName); } catch (System.Exception ex) { ed.WriteMessage(ex.Message); } } public static ObjectId GetBlkId(Database db, string blkName) { ObjectId blkId = ObjectId.Null; if (db == null) return ObjectId.Null; if (string.IsNullOrWhiteSpace(blkName)) return ObjectId.Null; using (Transaction tr = db.TransactionManager.StartTransaction()) { BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead); if (bt.Has(blkName)) blkId = bt[blkName]; tr.Commit(); } return blkId; } public static bool EraseBlkRefs(ObjectId blkId) { bool blkRefsErased = false; if (blkId.IsNull) return false; Database db = blkId.Database; if (db == null) return false; using (Transaction tr = db.TransactionManager.StartTransaction()) { BlockTableRecord blk = (BlockTableRecord)tr.GetObject(blkId, OpenMode.ForRead); var blkRefs = blk.GetBlockReferenceIds(true, true); if (blkRefs != null && blkRefs.Count > 0) { foreach (ObjectId blkRefId in blkRefs) { BlockReference blkRef = (BlockReference)tr.GetObject(blkRefId, OpenMode.ForWrite); blkRef.Erase(); } blkRefsErased = true; } tr.Commit(); } return blkRefsErased; } public static bool EraseBlk(ObjectId blkId) { bool blkIsErased = false; if (blkId.IsNull) return false; Database db = blkId.Database; if (db == null) return false; using (Transaction tr = db.TransactionManager.StartTransaction()) { BlockTableRecord blk = (BlockTableRecord)tr.GetObject(blkId, OpenMode.ForRead); var blkRefs = blk.GetBlockReferenceIds(true, true); if (blkRefs == null || blkRefs.Count == 0) { blk.UpgradeOpen(); blk.Erase(); blkIsErased = true; } tr.Commit(); } return blkIsErased; }
Thanks for the reply.
This solution works like dream!!Absolutely perfect for my problem!!
Simple and efficient solution!!
Regards
Aaditya Aggarwal
