@robertkellems73NEW , hi,
Since you've posted in the .NET programming forum I assume fou require a code solution.
How are you attempting to change the color by code ?
. . . post the code ( using the ,</> button on the expanded editor menu)
Are you attempting to modify a specific instance of a dimension ?
. . and a specific element (text line )
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>; another Swamper
