Please write source code to add and save an icon to the existing ribbon menu file in autocad .net.
Solved by ActivistInvestor. Go to Solution.
Since your post seems more like a ChatGPT prompt, as opposed to a legitimate question, here goes nothing:
Prompt (ChatGPT 3.5):
"Please write source code to add and save an icon to the existing ribbon menu file in autocad .net."
ChatGPT Response:
Certainly! To add and save an icon to the existing ribbon menu file in AutoCAD using .NET, you'll need to use the AutoCAD .NET API. Here's a basic example in C#:
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Windows;
public class RibbonAddIcon
[CommandMethod("AddIconToRibbon")]
public void AddIconToRibbon()
// Specify the path to your icon image file
string iconPath = "C:\\Path\\To\\Your\\Icon.png";
// Get the current AutoCAD ribbon
Ribbon ribbon = ComponentManager.Ribbon;
// Create a new ribbon button
RibbonButton button = new RibbonButton();
button.Text = "My Button";
button.ShowText = true;
button.Image = iconPath; // Set the icon image path
// Define the command to be executed when the button is clicked
button.CommandHandler = new RibbonCommandHandler();
// Add the button to an existing panel (replace "PanelName" with your desired panel)
RibbonPanel panel = ribbon.FindPanel("PanelName");
panel.Source.Items.Add(button);
// Save the changes to the ribbon
ribbon.UpdateLayout();
public class RibbonCommandHandler : ICommand
public void Execute(object parameter)
// Define the action to be performed when the button is clicked
// Add your code here
public bool CanExecute(object parameter)
return true;
public event EventHandler CanExecuteChanged;
Here's what this code does:
Remember to replace "PanelName" with the actual name of the panel you want to add the button to, and ensure that the icon file path is correct. Also, don't forget to handle the action you want to perform when the button is clicked inside the Execute method of the RibbonCommandHandler.Please adapt the code to your specific requirements and ensure it complies with your project's standards and practices."
As far as whether the above works or not I can't say because I really don't have the time to try it but feel free to knock yourself out.
