Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Subsurface artifacts
2 REPLIES 2
sidneygiormanivsfx
411 Views, 2 Replies
I am getting some strange green artifacts in my Subsurface channel when I render. Maya 2022 Arnold
The FACE has a Diffuse map, Roughness Map, and Normal map connected to the material and the diffuse map is driving the SSS color.
The BODY only has a Diffuse map driving the SSS color and nothing else linked to any other inputs. I am still getting the same results in the SSS channel of the render.
Labels (4)
2 REPLIES 2
The ss radius is to high.
https://linktr.ee/cg_oglu
Thank you It wasn't exactly the Radius but that did help me get to think that may the diffuse values were too high. Sure enough I had slightly boosted the exposure of the input filewhich is what caused it to be so apparent.
I did have to also reduce the scale quiet a bit to get the green on the edges of the mesh to come down to a manageable amount.
Generally I am satisfied though thank you!
