Ive been struggling with this project for hours straight now. Im using arnold to render out an animation I made of 850 frames. Last night I batch rendered, worked perfectly except my xgen materials didn't show. so I fixed that, and now when I try to batch render, arnold only produces one frame at a time. someone please help im currently batching each frame one by one
Solved by eal1SFAXJ. Go to Solution.
The info given is too scarce. If the render settings are allright, you'd inspect error messages.
At it's worst you can batch frame-by-frame rendering from RenderView > Render > RenderSequence.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
I figured it out. it was the abort error on checkbox. such a simple solution and I overlooked it so many times. I’m new to arnold so I figured it was one of those system settings I wasn’t ready to mess with yet. Thanks for your help!
What's the error in the Arnold log?
Generally we never tell users to ignore errors 😉
There was no error! I found in an auto desk forum that for arnold to batch render i needed to uncheck “abort on error” checkbox under diagnostics in render settings. I unchecked it and my batch render worked 🙂
Just had this same problem for the first time. Uncheck the abort on error box didn't help. But guess what did? Restarting Maya [hitting head on desk x5].
Im having the same issue. I unchecked the error box thingy but it's not working. i followed a tutorial and did everything theyve said but nothing is happening. Is there any other small things that i may have overlooked?
