Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Arnold only rendering one frame
6 REPLIES 6
eal1SFAXJ
2378 Views, 6 Replies
Ive been struggling with this project for hours straight now. Im using arnold to render out an animation I made of 850 frames. Last night I batch rendered, worked perfectly except my xgen materials didn't show. so I fixed that, and now when I try to batch render, arnold only produces one frame at a time. someone please help im currently batching each frame one by one
6 REPLIES 6
hamsterHamster
in reply to: eal1SFAXJ
The info given is too scarce. If the render settings are allright, you'd inspect error messages.
At it's worst you can batch frame-by-frame rendering from RenderView > Render > RenderSequence.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
eal1SFAXJ
in reply to: hamsterHamster
I figured it out. it was the abort error on checkbox. such a simple solution and I overlooked it so many times. I’m new to arnold so I figured it was one of those system settings I wasn’t ready to mess with yet. Thanks for your help!
Stephen.Blair
What's the error in the Arnold log?
Generally we never tell users to ignore errors 😉
// Stephen Blair
// Arnold Renderer Support
eal1SFAXJ
in reply to: Stephen.Blair
There was no error! I found in an auto desk forum that for arnold to batch render i needed to uncheck “abort on error” checkbox under diagnostics in render settings. I unchecked it and my batch render worked 🙂
cmurdo2003
Just had this same problem for the first time. Uncheck the abort on error box didn't help. But guess what did? Restarting Maya [hitting head on desk x5].
ellacroz
Im having the same issue. I unchecked the error box thingy but it's not working. i followed a tutorial and did everything theyve said but nothing is happening. Is there any other small things that i may have overlooked?
Technology Administrators
