pivot point bug when in vertex mode
Hello, so this has been bothering me in maya for a while and no one seems to know what this is.
Sometimes when i want to move a vertex on a complex object, the pivot point is stuck on another point and won't move. If i click D and then hold down V to move the pivot point to another vertex point it moves it there. However, I would have to do this every time, also, after I move the vertex point by using the arrows on the pivot point, the pivot point doesn't change location. It's stuck in that world space!
I searched for videos about understanding how changing pivot points works in maya and it works if I need to move the entire object itself, however not if I am in vertex mode.
I believe I somehow accidentally locked the pivot point to a world location  when I enter vertex mode, and it doesn't move.
If more screenshots are needed I can post them
mspeer
Hi!
1. Check in Channel Box if your Vertex is locked.
2. Try a reset of the Move Tool.
3. Try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
For further help please upload a scene-file.
rojicgartist
Community Visitor
Community Visitor
Even i faced this issue. I deleted history and it got fixed.
it's a bit late, but when you press D, then hold rightclick ob the yellow movetool square you can reset pivot position.
This will solve this issue
It's not to late! It was helpful for me!
Thank you!
Awesome. I was in struggle top, when i first faced this issue. Glad I could help 🙂
mikhailkonstantin3d
fantastic !
