Anytime I renderer xgen hair with Arnold, the hair disappears from the viewport. The hair will
Continue to render until I try to edit the hair in any way, or if I close the Arnold renderview and open it
Again, which both cause Maya to crash.
Hi @Anonymous
Do you have arnold shaders applied to the hair so they'll appear properly in the render?
Also, what GPU are you using and is the driver version the same as our certified hardware list?
You can find our certified hardware list here!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Arnold seems to render the hair just fine with or without arnold shaders applied.The hair disappears from
the viewport no matter what shader I'm using.
This is Maya 2017 with a gtx 1070 video card, I don't know the driver version off the top
of my head.
Hi @Anonymous
Ah my mistake I misread your original post.
If you click the preview button in the Xgen tab a few times does the hair appear again or is it still gone from the viewport?
Can you edit the hair and see the changes in the render even though it isnt showing in the viewport?
All the best,
Sean Heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
I was having the same issue. I worked on it at night everything was fine, went back at in the morning and it wouldn't show anymore. After clicking everything I realized that by turning off the face camera option, it would show the groom again. Anyways I don't know if that was just in my case but i hope it helps.
just convert it to poly and assign arnold hair shader. Never been lucky Autodesk helping to fix the bugs I encounter every now and then. Waiting for upgrades and a work around is the only way out. I just hope the newer versions don't require hardware upgrade.
