I have to insert an image plane for the back of my model, however whatever I do it will not allow me to go into the back view.
As you can see in the attached image that is the option that I should be seeing when I press space bar and hold right mouse click together. But I dont get anything,
Can someone help me please?
I found other options to make a perspective camera that is the back, but i need it lined up perfectly.
Solved by hamsterHamster. Go to Solution.
If Back doesn't work (strange), then you can make new camera, set it to Orthographic (e.g. perspShape->OrthographicViews) and, when looking through it, in the viewport menu, choose View>PredefinedBookmarks>Back
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
