Xgen Error, Sequence Render
Message 1 of 10
I am trying to render a character with xgen description. Every time I do a sequence render(300 frames), the rendering happens properly for about 6~7 frames and then the render stops and maya freezes. The output window gives the following error
XGen:O OppenCenCL Lerror ErroCL_EXEC_STATUS_ERROR_FOR_EVENTS_IN_WAIT_LISTr
: >Unknown error executing CL_COMMAND_NDRANGE_KERNEL on Quadro M2000 (Device 0).
S
:\Maya_2017_DOIp\src\MayaenCL\ Error:s rc\AWplugins\XGen\Unknown src\xgen\src\xgsceulptcrror executing CL_COMMAND_RELEASE_GL_OBJECTS on Quadro M2000 (Device 0).
o
re\XgOpenCLUtil.cpp(497): error: 'xgutil::enqueueReleaseHWObjects'
I am using Maya 2017 Update 3.
My GPU is Quadro M2000 and running the latest driver which support OpenCL.
Replies (9)
Message 2 of 10
sean.heasley
Hi @Anonymous and welcome to the community!
    What version of Maya are you on and is it up to date, also are all your drivers for your GPU etc. up to date? If so you can try deleting your settings and preferences to see if that changes anything.
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
    Hope this helps!
Message 3 of 10
sean.heasley
Hi @Anonymous just following up, let me know if this solved your issue!
Message 4 of 10
Hi Sean,
I am using Maya 2017, update 3 and all the GPU Drivers are up to date as well. Deleting all the Maya Preferences and re-setting the project was the first thing I did but unfortunately that did not solve the issue.
Initially, I was referencing the character and the sequence render was freezing after 6-7 frames. After that, I imported the objects into the scene. At first it looked like the problem was solved because it didn't freeze after the usual 6-7 frames, but eventually after 50 frames it froze again.
Although, with batch rendering this problem doesn't occur.
Message 5 of 10
Michael_Todd
That sounds like a memory leak in interactive rendering. Could you supply an example scene that has this problem for testing?
Michael Todd
XGen Product Owner and Designer
Message 6 of 10
sean.heasley
Hey @Anonymous just checking in did this solve your issue?
Message 7 of 10
Hi Michael,
Unfortunately, since I cannot provide the scene file as the source files are a property of someone else, but upon buying more licenses for Arnold Render I've been able to render it through batch rendering without a watermark. I shall try to re-create another scene and if it shows up the same error I can shall upload that scene.
Thank You
Message 8 of 10
sean.heasley
If the files are confidential you can send them in a private message to Michael or myself.
Message 9 of 10
sean.heasley
My error messages were different. I got these:
mental ray: version 3.14.3.41, 25 Feb 2017, revision 287619
mental ray: started on "BOS9CQPJH2", Fri Jun 09 11:44:35 2017
mental ray: Identified file "architectural.so" as identical to "architectural.dll"
mental ray: Identified file "paint.so" as identical to "paint.dll"
mental ray: Identified file "subsurface.so" as identical to "subsurface.dll"
mental ray: Identified file "layering.so" as identical to "layering.dll"
OXpGen: OpenCL error eCnCL Error: L_EXEC_STATUS_ERROR_FOR_EVENTS_IN_WAIT_LISTU
nknown error executing CL_COMMAND_ND>RANGE_KERNEL on Quadro M5000 (Device 0).
S
:\Maya_2017_DI\src\Maya\src\AWplugins\XGen\src\xgen\src\xgsculptcore\XgOpenCLUtil.cppO(p497): error: 'exgutil::enqueuenReleaseHWObjects'
CL Error: Unknown error executing CL_COMMAND_RELEASE_GL_OBJECTS on Quadro M5000 (Device 0).
I'm still looking into it but did Arnold rendering work for you?
Message 10 of 10
Yes, Arnold rendering worked perfectly fine for me. Using the batch render or still rendering , I had no issues at all.
