Hi guys could someone help me please? im getting this error in xgen and I don't know how to go about it?
C:/Program Files/Autodesk/Maya2017/plug-ins/xgen/presets/description/groom/region/Group23296.ptx (Part of path doesn't exist)
It happens when I try to create groomable splines on imported geometry.
and another error im getting is this: // Warning: file: C:/Program Files/Autodesk/Maya2017/plug-ins/xgen/scripts/xgmGuide.mel line 238: The associated guide ARM_RIGHT_SARM1_xgGuide5 does not exist. //
I get this error when I use guides as curves. Every time I try to modify it I get this error.
I was trying to look online for some solutions but I cant seem to find any answers.
SO please if anyone knows how to fix this I would be grateful.
thank you
Solved by Michael_Todd. Go to Solution.
Does the file exist in the location stated?
Hello Michael,
What if the file .ptx doesn't exist ? How can we create it to make it works ? And why does the path refer to a file which doesn't exist?
I have the same issue trying to paint a map whereas I just began my scene, and have set project, create uv, put lambert...
Hi, can you explain the steps to do this, Pls
I can't figure it out looking at the two screens shots.
thank you
Did you try to assign a Lambert Material to the object you want to paint ?
It worked for me. I had the problem when I assigned an aistandardsurface to the head. Assigning a lambert solve it.
Hope it'll work for you !
Setting the material of the model that xgen is using to a default lambert shader fixed the issue for me
i am having this error
// Error: line 1: XGen: Failed to find hair/paintmaps/Hair_mask/polySurface58.ptx //
// Error: line 1: XGen: Searched path includes:
C:/Users/zindo/Documents/3d/class/class_room/xgen/collections/groom_chracter/hair/paintmaps/Hair_mask/polySurface58.ptx (Part of path doesn't exist)
C:/Users/zindo/Documents/3d/class/class_room/xgen/collections/groom_chracter/hair/hair/paintmaps/Hair_mask/polySurface58.ptx (Part of path doesn't exist)
C:/Users/zindo/Documents/xgen/hair/paintmaps/Hair_mask/polySurface58.ptx (Part of path doesn't exist)
C:/Users/zindo/Documents/Maya2022/plug-ins/xgen/presets/hair/paintmaps/Hair_mask/polySurface58.ptx (Part of path doesn't exist) //
