Maya Forum
Welcome to Autodeskā€™s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Xgen error: Group23296.ptx (Part of path doesn't exist)
34 REPLIES 34
Message 1 of 35
43593 Views, 34 Replies
Hi guys could someone help me please? im getting this error in xgen and I don't know how to go about it?
  C:/Program Files/Autodesk/Maya2017/plug-ins/xgen/presets/description/groom/region/Group23296.ptx (Part of path doesn't exist)
It happens when I try to create groomable splines on imported geometry.
and another error im getting is this: // Warning: file: C:/Program Files/Autodesk/Maya2017/plug-ins/xgen/scripts/xgmGuide.mel line 238: The associated guide ARM_RIGHT_SARM1_xgGuide5 does not exist. //
I get this error when I use guides as curves. Every time I try to modify it I get this error.
I was trying to look online for some solutions but I cant seem to find any answers.
SO please if anyone knows how to fix this I would be grateful.
thank you
Tags (1)
34 REPLIES 34
Message 21 of 35
Michael_Todd
Does the file exist in the location stated?
Michael Todd
XGen Product Owner and Designer
Message 22 of 35
This error pops up when I try to paint the mask for a hairline--------
I have the same mistake
Message 23 of 35
in reply to: Michael_Todd
Hello Michael,
What if the file .ptx doesn't exist ? How can we create it to make it works ? And why does the path refer to a file which doesn't exist?
I have the same issue trying to paint a map whereas I just began my scene, and have set project, create uv, put lambert...
Message 24 of 35
I keep getting the same message!
Message 25 of 35
Hi, can you explain the steps to do this, Pls
I can't figure it out looking at the two screens shots.
thank you
Message 26 of 35
Did you try to assign a Lambert Material to the object you want to paint ?
It worked for me. I had the problem when I assigned an aistandardsurface to the head. Assigning a lambert solve it.
Hope it'll work for you !
Message 27 of 35
frazer.mcpherson
Setting the material of the model that xgen is using to a default lambert shader fixed the issue for me
Message 28 of 35
ks541082
Hi, But that's not work please help
Message 29 of 35
ks541082
And now hairs are showing? What can I do?
Message 30 of 35
ks541082
Still The same errors and no hairs?
Message 31 of 35
ks541082
That's not working
Message 32 of 35
migara666
Try a new Maya version
Message 33 of 35
zindonda09
i am having this error
// Error: line 1: XGen: Failed to find hair/paintmaps/Hair_mask/polySurface58.ptx //
// Error: line 1: XGen: Searched path includes:
C:/Users/zindo/Documents/3d/class/class_room/xgen/collections/groom_chracter/hair/paintmaps/Hair_mask/polySurface58.ptx (Part of path doesn't exist)
C:/Users/zindo/Documents/3d/class/class_room/xgen/collections/groom_chracter/hair/hair/paintmaps/Hair_mask/polySurface58.ptx (Part of path doesn't exist)
C:/Users/zindo/Documents/xgen/hair/paintmaps/Hair_mask/polySurface58.ptx (Part of path doesn't exist)
C:/Users/zindo/Documents/Maya2022/plug-ins/xgen/presets/hair/paintmaps/Hair_mask/polySurface58.ptx (Part of path doesn't exist) //
Message 34 of 35
catrielmamani
I solved the problem that I had regarding the fact that the hair could not be seen in xgen, or it seemed that it did not generate it, you just have to deactivate the button "use default material" which is in the viewport bar
Message 35 of 35
angelozallu88
i have got the same problem on Maya 2024.....
I set my project in a different directory
Xgen keeps looking on Autodesk directory.
C:/Program Files/Autodesk/Maya2024/plug-ins/xgen/presets/top_head/paintmaps/mask/body_final.ptx (Part of path doesn't exist)
WHY WHY WHY WHY?
