Xgen error: Group23296.ptx (Part of path doesn't exist)
This widget could not be displayed.
Hi guys could someone help me please? im getting this error in xgen and I don't know how to go about it?
  C:/Program Files/Autodesk/Maya2017/plug-ins/xgen/presets/description/groom/region/Group23296.ptx (Part of path doesn't exist)
It happens when I try to create groomable splines on imported geometry.
and another error im getting is this: // Warning: file: C:/Program Files/Autodesk/Maya2017/plug-ins/xgen/scripts/xgmGuide.mel line 238: The associated guide ARM_RIGHT_SARM1_xgGuide5 does not exist. //
I get this error when I use guides as curves. Every time I try to modify it I get this error.
I was trying to look online for some solutions but I cant seem to find any answers.
SO please if anyone knows how to fix this I would be grateful.
thank you
Replies (34)
Michael_Todd
Does the file exist in the location stated?
Michael Todd
XGen Product Owner and Designer
This error pops up when I try to paint the mask for a hairline--------
I have the same mistake
Hello Michael,
What if the file .ptx doesn't exist ? How can we create it to make it works ? And why does the path refer to a file which doesn't exist?
I have the same issue trying to paint a map whereas I just began my scene, and have set project, create uv, put lambert...
I keep getting the same message!
Hi, can you explain the steps to do this, Pls
I can't figure it out looking at the two screens shots.
thank you
Did you try to assign a Lambert Material to the object you want to paint ?
It worked for me. I had the problem when I assigned an aistandardsurface to the head. Assigning a lambert solve it.
Hope it'll work for you !
frazer.mcpherson
Community Visitor
Community Visitor
Setting the material of the model that xgen is using to a default lambert shader fixed the issue for me
ks541082
Observer
Observer
Hi, But that's not work please help
ks541082
Observer
Observer
And now hairs are showing? What can I do?
ks541082
Observer
Observer
Still The same errors and no hairs?
ks541082
Observer
Observer
That's not working
migara666
Community Visitor
Community Visitor
Try a new Maya version
zindonda09
Community Visitor
Community Visitor
i am having this error
// Error: line 1: XGen: Failed to find hair/paintmaps/Hair_mask/polySurface58.ptx //
// Error: line 1: XGen: Searched path includes:
C:/Users/zindo/Documents/3d/class/class_room/xgen/collections/groom_chracter/hair/paintmaps/Hair_mask/polySurface58.ptx (Part of path doesn't exist)
C:/Users/zindo/Documents/3d/class/class_room/xgen/collections/groom_chracter/hair/hair/paintmaps/Hair_mask/polySurface58.ptx (Part of path doesn't exist)
C:/Users/zindo/Documents/xgen/hair/paintmaps/Hair_mask/polySurface58.ptx (Part of path doesn't exist)
C:/Users/zindo/Documents/Maya2022/plug-ins/xgen/presets/hair/paintmaps/Hair_mask/polySurface58.ptx (Part of path doesn't exist) //
catrielmamani
Observer
Observer
I solved the problem that I had regarding the fact that the hair could not be seen in xgen, or it seemed that it did not generate it, you just have to deactivate the button "use default material" which is in the viewport bar
angelozallu88
Community Visitor
Community Visitor
i have got the same problem on Maya 2024.....
I set my project in a different directory
Xgen keeps looking on Autodesk directory.
C:/Program Files/Autodesk/Maya2024/plug-ins/xgen/presets/top_head/paintmaps/mask/body_final.ptx (Part of path doesn't exist)
WHY WHY WHY WHY?
