Unfold3d Process error
Message 1 of 104
Hello
This error is occuring whenever i try to unwrap a slightly complex object like a face or body using the Unwrap or Optimize commands. This is a new computer and it is using a Ryzen 9 CPU if that makes any difference. Also a fresh install
Things i have tried:
1. Disabling and re-enabling the unfold3d plugin
2. uninstalling and re-installing maya 2019
3. using maya 2018
4. shrinking the object so its smaller
5. unwrapping different objects from old projects that i have already successfully unwrapped in the past using unfold3d
6.unwrapping with Houdini or Blender (works!)
7. wrapping in zbrush (works!)
8. unwrapping using Maya 2019 on my work computer (works!)
9. reseting to default preferences.
So it appears to be some kind of system issue but i have already tried uninstalling and reinstalling maya several times. as well as registry cleaning/rebooting in between.
Replies (103)
Message 101 of 104
Unfolding still crashes maya 2022 for me. Simple meshes are fine, but anything mid-high poly crashes maya more often than not. Threadripper 2950x. I'm forced to use standalone unfold or blender :D. Thanks ADSK .
Message 102 of 104
imstudent1712
thank you buddy
Message 103 of 104
zhiweiyew0912
Community Visitor
Community Visitor
ITS WORKING TQSM
Message 104 of 104
Thank you so much! It worked Maya 2018
