Unfold3d Process error
Message 1 of 104
Hello
This error is occuring whenever i try to unwrap a slightly complex object like a face or body using the Unwrap or Optimize commands. This is a new computer and it is using a Ryzen 9 CPU if that makes any difference. Also a fresh install
Things i have tried:
1. Disabling and re-enabling the unfold3d plugin
2. uninstalling and re-installing maya 2019
3. using maya 2018
4. shrinking the object so its smaller
5. unwrapping different objects from old projects that i have already successfully unwrapped in the past using unfold3d
6.unwrapping with Houdini or Blender (works!)
7. wrapping in zbrush (works!)
8. unwrapping using Maya 2019 on my work computer (works!)
9. reseting to default preferences.
So it appears to be some kind of system issue but i have already tried uninstalling and reinstalling maya several times. as well as registry cleaning/rebooting in between.
Replies (103)
Message 81 of 104
Thank you so much this is only thing worked here, I updated my pc with a amd ryzen9 3900x, and worked!!!
thanks!!😁
Message 82 of 104
Couldn't get the environment variable fix to work on my Ryzen 7 3700x machine running Maya 2020.1
@T0M0X 's fix worked great. Thanks @T0M0X
Autodesk should get their finger out and fix this one really given how many people are running AMD machines these days.
Message 83 of 104
mspeer
Hi!
You need at least Maya 2020.2, if you want to use the environment variable with Maya 2020 .
Message 84 of 104
mdesjardins
Observer
Observer
Message 85 of 104
this worked so well! thank you so much. Ryzen effecting the unfolding process was really frustrating.
Message 86 of 104
I very recently got a new PC with lots of ryzen components, so Im so glad i found this solution! Seems to be working perfectly. Thanks so much for sharing!
Message 87 of 104
haukakei
Observer
Observer
Thanks TOMOX!!! It works for Ryzen9 3900X!!
Message 88 of 104
jeancarlosoecksler
Thank you so much!
Jean Oecksler
3D Student
www.vimeo.com/jeanoecksler
www.linkedin.com/in/jeanoecksler
Message 89 of 104
many thanks!!!!!!!!!!👍🔥🚀
Message 90 of 104
ronald_fodex
JUST TO SAYYY!!!
THANKS MAN..... Works fine for 2018 -- Ryzen 3600
Message 91 of 104
miguel.garcia.vieira
Awesome solution, it works!!!
Don't touch the 2017 shim file 😉
Message 92 of 104
Thank you! It worked!
Message 93 of 104
ewu77A7V
Observer
Observer
Thank you, this fixed my problem 🙂
Message 94 of 104
ellouisa.lucy
Observer
Observer
Hi, I have the same issue using the latest version of maya and have a ryzen. Its been working fine for 3 weeks, no issues, unfolded a semisphere, worked great, messed up later on and when I went to unfold the semisphere again I got this error for the first time. Now I get it everytime on any spherical object. I can't use legacy because the results are horrible. I've tried following a link that advises downloading a rar file, and copy and replacing a shim file, this didn't work. Neither did clean Uninstalling and reinstalling maya. I'm at a loss now, can anyone help please?
Message 95 of 104
2373377814
Community Visitor
Community Visitor
Thank you very much. The problem is AMDCPU
Message 96 of 104
jaromir.stifter
Worked!!! Thank you so much. Literal life saver!
Message 97 of 104
Thank you it works!!!
Message 98 of 104
kaiden
Observer
Observer
Autodesk, Tomox just saved you from a refund. Fix your $1000 program!
Message 99 of 104
you are the best! it worked maya 2019
Message 100 of 104
halk.kbmaya
Observer
Observer
Thanks you! You've just saved my life))
