Restoring saved shelves
dersutton
Message 1 of 11
dersutton
Hello
I've created a customized shelf for myself and I know where the "save all shelves" option is so the only question I really have is how to restore the shelf/tools in the event that they have been deleted?
Thank you.
Replies (10)
Message 2 of 11
sean.heasley
Hi @dersutton
Do you have the custom shelf in your prefs folder?
If its not there you may need to remake the shelf and then make sure the file is saved in your prefs folder.
Please let me know if anything changes!
Message 3 of 11
sean.heasley
Hi @dersutton
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 4 of 11
dersutton
Hi Sean
Sorry for the late reply.  I just found your email now.
As per my question I'm actually looking at my interface right now and I've gone into settings and selected "save all shelves" but I'm not being prompted as where to save them so I honestly can't say where they are.
I'd appreciate your input as to what I'm doing wrong.
Derek
Message 5 of 11
sean.heasley
Hi @dersutton
If you navigate to Documents\maya\2018\prefs\shelves you should be able to see a list of the shelves in Maya including any custom shelves you may have.
Let me know if anything changes!
Message 6 of 11
sean.heasley
Hi @dersutton
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 7 of 11
dersutton
Hi Sean
I found the directory you mentioned.   Is the file called "MTKShelf"?   If so, then I located it.
Is that what I am to look for?
Derek
Message 8 of 11
sean.heasley
Hi @dersutton
Your shelves folder can be found in your Prefs folder and should look something like this:
From here you can find the problem shelf and delete/restore them.
Message 9 of 11
dersutton
I'm currently using Maya 2016.    After looking at the Pref folder again I found a file called "shelf_custom".  I'm guessing that is the correct one?
Message 10 of 11
sean.heasley
Hi @dersutton
That sounds like it should be it.
Also, please make a back up of the prefs folder that way if anything goes wrong you can restore your settings!
Message 11 of 11
dersutton
 Hi Sean
Thanks for your help.  Much appreciated.
Derek
