Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Top. side, left viewer doesnt display
4 REPLIES 4
452 Views, 4 Replies
Please help me with the troubles
My viewer from top, side, left doesnt display anything.
4 REPLIES 4
sean.heasley
Hi @Anonymous and welcome to the community!
While you unistalled/reinstalled that might not have wiped your preferences so I would recommend deleting your settings/preferences.
If that doesn't help, can you please let me know what GPU you are using and if the drivers are up to date?
Steps to update your drivers can be found here!
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
in reply to: sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Sorry for replying late. I already found the solution after that. I deleted the pref folder as you said. The point is It work but when i changed the unit to meter, the camera of these side doesn’t display again. I found that I changed the unit in the wrong way ( New scene setting) instead of go to setting/preferences.
Thank you for replying me and your solutions
mspeer
Hi!
You need to adjust Clipping Planes (and maybe position) of cameras when changing units.
