Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Problem opening file size more than 15mb in maya 2018
3 REPLIES 3
795 Views, 3 Replies
hello
i have file size is 26 mb, it has .ma formate the file is openign in maya 2014 but its not opening  in maya 2018. i treid all ways to open scene but its not workout.
any help i appreciate
 thankyou
https://drive.google.com/open?id=0B_m-pLYBxHZ5RVZXS3BzUTFUMVk
3 REPLIES 3
mspeer
Hi!
This scene requires Mental Ray, so wait for Mental Ray for Maya 2018 to be released, or use Maya 2017 (with MR plug-in) to open the scene.
john.paul.giancarlo
Hello I manage commented out the MR nodes with a Text Editor,  I was not able to recover the rig but the model seems to be there !
I added a quick Human IK rig to it !
The only way to fix this is in a text editor but it wont be easy it will take a lot of trial and error but it can be done, or try getting the MR plugin, that might work, although I would change mayas evaluation mode from parallel to DG as this is an old rig !
please find the maya file attached.
I know it does not solve the problem but it is a good start !
Hi @Anonymous
I'm checking in to see if any of the posts above worked or if you need more assistance.
Did the suggestion that @john.paul.giancarlo or @mspeer provide work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Technology Administrators
