hello
i have file size is 26 mb, it has .ma formate the file is openign in maya 2014 but its not opening in maya 2018. i treid all ways to open scene but its not workout.
any help i appreciate
thankyou
https://drive.google.com/open?id=0B_m-pLYBxHZ5RVZXS3BzUTFUMVk
hello
thankyou
Solved by john.paul.giancarlo. Go to Solution.
Solved by mspeer. Go to Solution.
Hi!
This scene requires Mental Ray, so wait for Mental Ray for Maya 2018 to be released, or use Maya 2017 (with MR plug-in) to open the scene.
Hi!
Hello I manage commented out the MR nodes with a Text Editor, I was not able to recover the rig but the model seems to be there !
I added a quick Human IK rig to it !
The only way to fix this is in a text editor but it wont be easy it will take a lot of trial and error but it can be done, or try getting the MR plugin, that might work, although I would change mayas evaluation mode from parallel to DG as this is an old rig !
please find the maya file attached.
I know it does not solve the problem but it is a good start !
Hi @Anonymous
I'm checking in to see if any of the posts above worked or if you need more assistance.
Did the suggestion that @john.paul.giancarlo or @mspeer provide work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
All the best,
Sean Heasley
