OpenCL evaluator is attempting to initialize OpenCL.
Message 1 of 19
Hi, Im unable to Use Maya in Discrete mode.
Only in Optimus mode.
Im using Zephyrus M Gm501 GTx 1060
Here's my output window:
Initialized VP2.0 renderer {
Version : 6.3.16.0. Feature Level 4.
Adapter : GeForce GTX 1060/PCIe/SSE2
Vendor ID: 4318. Device ID : 7264
Driver : .
API : OpenGL V.4.6.
Max texture size : 32768 * 32768.
Max tex coords : 8
Shader versions supported (Vertex: 4, Geometry: 4, Pixel 4).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 6144 MB.
CPU Memory Limit: 15489.5 MB.
Fatal Error. Attempting to save in ...
Replies (18)
Message 2 of 19
sean.heasley
Hi @Anonymous and welcome to the community!
Are your GPU drivers the same as our certified hardware list?
You can find our certified hardware list here!
When you say discrete and optimus, is that a setting with your GPU?
If a driver change doesn't help, you could open your Maya.env file and add this line to it:
MAYA_OPENCL_IGNORE_DRIVER_VERSION = 1
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 3 of 19
Tried the maya.env thingy. didnt work.
Its a setting for the gpu. Not sure if its only exclusive for asus. Switching Between discrete and optimus mode, required restart. Currently using gtx 1060 max q
Message 4 of 19
sean.heasley
Hi @Anonymous
What specific driver version are you using?
Our officially supported driver for the 1060 is version  390.77.
If you aren't using that, please uninstall your current drivers and install version 390.77 which can be found here!
Message 5 of 19
I cant seem to even install the driver. unable to find compatible graphic hardware.
Message 6 of 19
It work when i switch to optimus mode, not discrete. probably because i installed during optimus mode.
Message 7 of 19
sean.heasley
Hi @Anonymous
Is there a reason you are trying to work in discrete mode?
Its possible this is an issue with the GPU feature and not Maya itself.
Message 8 of 19
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 9 of 19
Yea cause i normally use discrete mode, cause if i want to use maya i need to restart to change modes. Which is annoying. Is there a way to clean install the graphic driver for maya?
Message 10 of 19
sean.heasley
Hi @Anonymous
Nvidia has steps on rolling back drivers you can find here!
Option 1: Roll Back To Your Previous Driver:
  1. Click Start
  2. Click Control Panel
  3. Windows Vista: Click System and Maintenance and then System or simply System (in Classic view). Windows 7: Click System and Security and then System.
  4. In the left pane, click Device Manager
  5. Double-click on Display Adapters
  6. Double-click on your NVIDIA GPU
  7. Select the Driver Tab
  8. Click on Roll Back Driver
Option 2: Uninstall the Current Driver:
When you installed your current driver, if you first uninstalled the previous driver you won’t be able to roll back. In this case, follow the same steps that you previously used to uninstall your driver. Once complete, you can then download and re-install the recommended driver.
Message 11 of 19
I think it might be Maya Installed in a different display adapter, thats why i cant open in Discrete mode. When i switch, its says switching display adapter.
Message 12 of 19
This is what i get when im able to open it
Vendor ID: 4318. Device ID : 16027
Driver : .
API : OpenGL V.4.6.
Max tex coords : 8
CPU Memory Limit: 15421.1 MB.
Detected 2 OpenCL Platforms:
0: Intel(R) Corporation. Intel(R) OpenCL. OpenCL 2.1 .
Supported extensions: cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_fp64 cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_image2d_from_buffer cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_spir
1: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 9.2.189.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
Choosing OpenCL Device GeForce GTX 1060. Device Type: GPU Device is available.
Message 13 of 19
sean.heasley
Hi @Anonymous
Hmmm what you could do is check the back of your pc and see where you plugged in your display cable.
Sometimes a pc will come with your GPU and an onboard card. While plugging into the onboard card can work, it can also cause issues when you aren't properly connected directly to the gpu.
Message 14 of 19
Im using a laptop and theres a intel software running whenever I switch to Optimus mode.
Message 15 of 19
sean.heasley
Hi @Anonymous
You could try disabling/uninstalling that.
This doesn't really sound like an issue with Maya more so an issue with your GPU and/or the software you're using with it when using optimus/discrete mode
Message 16 of 19
sean.heasley
Hi @Anonymous
Message 17 of 19
Message 18 of 19
I have this problem and I need a quick solution.
Version : 2016.11.53.12. Feature Level 5.
Adapter : Intel(R) UHD Graphics 630
Vendor ID: 32902. Device ID : 7809
Driver : .
API : OpenGL V.4.6.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
GPU Memory Limit : 4095 MB.
CPU Memory Limit: 62100.4 MB.
MultiDraw consolidation: enabled
0: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 11.2.135.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid
1: Intel(R) Corporation. Intel(R) OpenCL HD Graphics. OpenCL 2.1 .
OpenCL evaluator failed to find OpenCL device with vendor Intel(R) Corporation.
Message 19 of 19
AlexGarreth
Community Visitor
Community Visitor
Can someone help me I get this error when opening maya 2019
Version : 2016.11.44.12. Feature Level 5.
Vendor ID: 32902. Device ID : 35414
Driver : C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_7b349056b76317ca\igdumdim64.dll,C:\WINDOWS\System32\DriverSto:27.20.100.8280.
API : DirectX V.11.
Max tex coords : 32
GPU Memory Limit : 1024 MB.
CPU Memory Limit: 3670.02 MB.
Detected 1 OpenCL Platforms:
0: Intel(R) Corporation. Intel(R) OpenCL HD Graphics. OpenCL 2.1 .
