I'm trying to export a college project as an Obj to bring it into Substance painter, but I export the blade (there are 4 pieces and i have tried grouping them and merging them too) i choose the Obj export option and export selection but when i go into my documents it shows that it is a 3D object file and i really need help with this.
Solved by sean.heasley. Go to Solution.
Hi @Anonymous
While windows will say 3D object file you should still be able to import it into Substance. Is importing not working for you?
If its not working, you could try unloading and reloading the OBJ export plugin or you could also try exporting as an FBX and then import that into Substance.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
