node editor, nodes keep rearranging
reniferziolo
Message 1 of 69
reniferziolo
Hello everyone,
Whenever I connect nodes to chosen "channels" they jump around the node editor viewport, making me loose track of my progress. It's really confusing. I don't know how to fix this. Any help appreciated!
Replies (68)
Message 2 of 69
NandoStille
The Node Editor is far from being an elegant tool. Don't expect to much.
But see here: https://forums.autodesk.com/t5/maya-forum/node-editor-pin-all-nodes-by-default/m-p/7850063
Message 3 of 69
sean.heasley
Hi @reniferziolo
@NandoStille made a good point and using pin settings should help.
That said, I haven't seen much of the issue you're describing before.
When you get a chance, can you please post a video of what's happening on your machine so I can get a better idea of the issue?
If you need a video capturing program, Screencast is a great option that we use here at Autodesk
Please let me know if anything changes!
Message 4 of 69
reniferziolo
Hello.
Thank you for your suggestions. Unfortunately pinning by default does ..nothing.  I didn't have a chance to  record it by here are snaps of the default arrangement and the one that follows.  It can be really confusing with with more dense "networks". Ok so  here goes.defaultdefaultresultresult
Message 5 of 69
sean.heasley
Hi @reniferziolo
I'm a bit confused by this.
Do you make any changes to the node editor when this happens or do you just close it when its like the Default and then re open it and it looks like the result in the second screenshot?
Message 6 of 69
reniferziolo
it happens the moment I plug the node in and the unit convertion node is being created.
kind regards
Message 7 of 69
sean.heasley
Hi @reniferziolo
Ohh ok I get what you're talking about.
I've seen this as well and I believe it is by design. The reason it is moved a bit away from the nodes is that you can clearly see something has been added in between the two nodes, in this case the Unit Conversion node.
I'm a bit surprised it's causing an issue for you since I've only had it move a few units so it's relatively easy to move back into place but that said, I also keep my nodes separated with a lot of space in between groups so its a bit easier to not what is where etc.
Message 8 of 69
reniferziolo
It was very confusing with more dense networks. I just recreated the issue.
Thanks for you time.
Message 9 of 69
Martin_L_A
No offense, but if it is by design, it is a very poor design.
In the example given by
Message 10 of 69
reniferziolo
I agree. As I said it's much worse with denser networks.It's a pity because I find node editor to be easer for some tasks than writing expressions. Maybe something worth looking into for future builds?
Message 11 of 69
sean.heasley
Hi @reniferziolo
It is worth looking into of course and I actually already passed this along to the developers as a note so they have it on their radar.
It'd be helpful it this was a bit easier to reproduce because like I mentioned previously, I only see the nodes move a handful of units and it's never thrown off my workflow.
That said, if a node is moving extremely far away like @NandoStille mentioned then this is a much more serious issue that needs to be addressed.
If at all possible, could you post repro steps and/or a video of this happening on your machine so I can pass it along to the dev report?
Message 12 of 69
Martin_L_A
This is also annoying by default, even when it's just a few units away. For example, I often have dozens of nodes displayed, that I spend time rearranging, and then need to connect all of them to another series of nodes.
2 solutions then, either we connect them manually one by one, rearranging them one after the other (and rearranging, when you have a few dozen nodes, will take more time than connecting the nodes themselves) losing a massive amount of time for just an annoying feature; or you can use a line of code to connect all of them, and you get your whole graph messed up at once. And then have to rearrange it, losing more time than it took you to connect them.
And the down side is that, since the update, I coulnd't even find a way to get my rigging nodes displayed in the hyperShade like they used to (because at least, the hyperShade is not messing my work).
In my opinion, nodes shouldn't move after their creation, unless explicitly told so (by using the rearrange button, or being moved by the user).
Message 13 of 69
NandoStille
I completely agree with everything you wrote and I wish more rigging and shading artists would speak up here. There are (and have been before) other, proper "node editors" out there - ahead of Maya's attempt to implement one (at a time when the Hypergraph was deprecated long ago). Editors which set standards and still do and which are a pure delight to work with. Several concepts of the Maya NodeEditor are just producing raised eyebrows against this background.
A few examples: a "feature" like pinning nodes is really just a fix for bad interface design. The "Add on Create" and "Additive Graphing" options produce confusing outcomes in certain situations - which is also caused by the fact, that the NE and the HS are sharing(!) these options, which I never understood.
In the end such well-meant "features" are just producing redundant clicks - unfortunately something Maya is really good at - which wouldn't be necessary if the tool was done right.
Last but not least, the NE is bugged and suffers inconsistent menus, like the "Display" section in the RMB marking menu. But no wonder if one considers the flashy way how the HS UI rebuilds itself every time one opens the editor. Seriously? Again, smells like bad ui design, don't you think?
I am sure alot is already logged and so as a good and patient and obedient - and unfortunately still in a certain way bound-to Maya artist - I just hope it get's better ... somewhen ... in the future ... near future.
Message 14 of 69
johnkeates2865
I am getting this odd 'nodes jumping around' behavior in Maya 2018 sp4 and it is a handicap.
I really would like to turn off the re-arrangement of nodes as it is never useful and makes everything take much longer to do. It is a bad idea, poorly implemented.
Message 15 of 69
johnkeates2865
To add: I tried 'pin all nodes by defualt' but still the view of the node editor keeps skipping about. It is infuriating (I don't go on these boards for fun). I can move the view perfectly well myself and some hastily assembled algorithm cant!
Message 16 of 69
stuff
Node editor is the reason why I still rig with Maya 2015!
It started getting bad with 2016 where nodes duplicated outside the focused on area, then 2017 where attributes started disappearing after connecting them once for some reason?? and in 2018 nothing was fixed.
The fact that Autodesk designed it like this shows that they lack understanding of how people work. Sure it's all fancy and flashy for the keynotes to show how you can open nodes and show everyone ALL of the attributes... Wow! what an achievement. But I dare you to rig a foot roll for a character using the node editor without going insane with the nodes jumping around, rearranging undesirably and attributes disappearing after one connection!
Maya 2015 is where it was at.
Message 17 of 69
johnkeates2865
Can this issue be 'unsolved' and worked on please? Before someone using the node editor goes postal?
Best to have a mode where the camera and nodes don't re-arrange themselves until someone has worked out how to make that work in a way which isn't annoying.
Message 18 of 69
stuff
At the very Very least, just make a switch to turn rearrangement and disappearing attributes OFF!... Is that so hard, Autodesk?
Message 19 of 69
paulluttrellTA
Yeah this is ridiculous. I'm a technical artist and it sets me back so much every time Maya scatters my carefully created nodes all over the place
Message 20 of 69
Martin_L_A
I believe that is indeed a very common feeling within the video games/vfx industry and among Maya users in general, but that thread (and so many others) have been closed for so long because this "is by design" that now I tend to think that Autodesk believes its design is more important than its users and their feedback.
This is probably why there is an increasing number of people and studios switching over from Autodesk products to blender / SideFX / Foundry  products. Fortunately for us there are at least some other software companies that understand that the users are more important than their products.
