ERROR: Could not find a version that satisfies the requirement pymel==1.2.0 (from versions: none)
marietto2008
marietto2008
Hello.
I've installed maya 2022 on Ubuntu 20.04. Everything works great except "Pymel2022_64-2022.0-22.0.0.0.x86_64.rpm",
that can't be installed because a python / SSL ? error.
This is the version of python installed as default on Ubuntu 20.04 :
# python3 --version
Python 3.8.10
Below you can see the error that I get. I hope that someone can help me to fix it.
# alien -vc Pymel2022_64-2022.0-22.0.0.0.x86_64.rpm
# apt install libssl-dev
# dpkg -i pymel2022-64_2022.0-23_amd64.deb
# ln -s /usr/lib/x86_64-linux-gnu/libssl.so.1.1 /usr/autodesk/maya2022/lib/libssl.so.10
Selecting previously unselected package pymel2022-64.
(Reading database ... 673134 files and directories currently installed.)
Preparing to unpack pymel2022-64_2022.0-23_amd64.deb ...
Unpacking pymel2022-64 (2022.0-23) ...
Setting up pymel2022-64 (2022.0-23) ...
WARNING: pip is configured with locations that require TLS/SSL, however the ssl module in Python is not available.
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.")': /simple/pymel/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.")': /simple/pymel/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.")': /simple/pymel/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.")': /simple/pymel/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.")': /simple/pymel/
ERROR: No matching distribution found for pymel==1.2.0
dpkg: error processing package pymel2022-64 (--install):
installed pymel2022-64 package post-installation script subprocess returned error exit status 1
Errors were encountered while processing.
# ./mayapy -m pip list
Package Version
future 0.18.2
pip 20.2
setuptools 41.2.0
Could not fetch URL https://pypi.org/simple/pip/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host='pypi.org', port=443): Max retries exceeded with url: /simple/pip/ (Caused by SSLError("Can't connect to HTTPS URL because the SSL module is not available.")) - skipping
# apt install python3-pip
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
libexpat1-dev libpython3-dev libpython3.8-dev python-pip-whl python3-dev python3-setuptools python3-wheel
python3.8-dev
Suggested packages:
python-setuptools-doc
The following NEW packages will be installed:
libexpat1-dev libpython3-dev libpython3.8-dev python-pip-whl python3-dev python3-pip python3-setuptools
python3-wheel python3.8-dev
0 upgraded, 9 newly installed, 0 to remove and 4 not upgraded.
1 not fully installed or removed.
Need to get 6.980 kB of archives.
After this operation, 26,4 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://it.archive.ubuntu.com/ubuntu focal-updates/main amd64 libexpat1-dev amd64 2.2.9-1ubuntu0.4 [117 kB]
Get:2 http://it.archive.ubuntu.com/ubuntu focal-updates/main amd64 libpython3.8-dev amd64 3.8.10-0ubuntu1~20.04.4 [3.952 kB]
Get:3 http://it.archive.ubuntu.com/ubuntu focal/main amd64 libpython3-dev amd64 3.8.2-0ubuntu2 [7.236 B]
Get:4 http://it.archive.ubuntu.com/ubuntu focal-updates/universe amd64 python-pip-whl all 20.0.2-5ubuntu1.6 [1.805 kB]
Get:5 http://it.archive.ubuntu.com/ubuntu focal-updates/main amd64 python3.8-dev amd64 3.8.10-0ubuntu1~20.04.4 [514 kB]
Get:6 http://it.archive.ubuntu.com/ubuntu focal/main amd64 python3-dev amd64 3.8.2-0ubuntu2 [1.212 B]
Get:7 http://it.archive.ubuntu.com/ubuntu focal/main amd64 python3-setuptools all 45.2.0-1 [330 kB]
Get:8 http://it.archive.ubuntu.com/ubuntu focal/universe amd64 python3-wheel all 0.34.2-1 [23,8 kB]
Get:9 http://it.archive.ubuntu.com/ubuntu focal-updates/universe amd64 python3-pip all 20.0.2-5ubuntu1.6 [231 kB]
dpkg: error processing package pymel2022-64 (--configure):
Setting up python-pip-whl (20.0.2-5ubuntu1.6) ...
Setting up libpython3-dev:amd64 (3.8.2-0ubuntu2) ...
Setting up python3-dev (3.8.2-0ubuntu2) ...
Setting up python3-pip (20.0.2-5ubuntu1.6) ...
Processing triggers for man-db (2.9.1-1) ...
Errors were encountered while processing:
pymel2022-64
E: Sub-process /usr/bin/dpkg returned an error code (1)
# pip3 install ssl
Collecting ssl
Downloading ssl-1.16.tar.gz (33 kB)
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-ljd83g4k/ssl/setup.py'"'"'; __file__='"'"'/tmp/pip-install-ljd83g4k/ssl/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-install-ljd83g4k/ssl/pip-egg-info
cwd: /tmp/pip-install-ljd83g4k/ssl/
Complete output (30 lines):
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/tmp/pip-install-ljd83g4k/ssl/setup.py", line 33
print 'looking for', f
SyntaxError: Missing parentheses in call to 'print'. Did you mean print('looking for', f)?
Error in sys.excepthook:
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 72, in apport_excepthook
from apport.fileutils import likely_packaged, get_recent_crashes
File "/usr/lib/python3/dist-packages/apport/__init__.py", line 5, in <module>
from apport.report import Report
File "/usr/lib/python3/dist-packages/apport/report.py", line 21, in <module>
from urllib.request import urlopen
File "/usr/lib/python3.8/urllib/request.py", line 88, in <module>
import http.client
File "/usr/lib/python3.8/http/client.py", line 1368, in <module>
import ssl
File "/tmp/pip-install-ljd83g4k/ssl/ssl/__init__.py", line 140
except SSLError, x:
SyntaxError: invalid syntax
Original exception was:
ERROR: Command errored out with exit status 1: python setup.py egg_info
Check the logs for full command output.
/usr/autodesk/maya2022/bin/python-bin -m pip install ssl
ERROR: Could not find a version that satisfies the requirement ssl (from versions: none)
ERROR: No matching distribution found for ssl
snw76NPW
Community Visitor
Community Visitor
The real issue here is that the compiled version of Python which ships with Maya installs on Ubuntu is bad, and doesn't link to the proper SSL library, which means that when you try and install pymel (which tries to do a pip install using Maya's python) it doesn't work- that's why you're getting all the SSL errors.
The issue isn't your system's python, it's Maya's.
To solve:
1. Assuming you're following https://knowledge.autodesk.com/support/maya/learn-explore/caas/simplecontent/content/installing-maya... , make sure that the libraries you are sudo ln-s'ing actually exist. That means installing libssl1 explicitly, etc.
2. Compile and install Python3.7 to your Ubuntu install
3. In Maya's lib folder (/usr/autodesk/maya2022/lib/) move the python3.7 folder to python3.7.bak
4. Make a new python3.7 dir, cd into it, and copy your newly compiled Python3.7 libraries here- (sudo cp /usr/local/lib/python3.7/* ./ -R)
5. cd into the new site-packages folder, and copy the .bak's site-packages here (sudo cp -R ../../python3.7.bak/site-packages/* ./)
6. Reinstall pymel, first by canceling the failed install (sudo apt-get remove pymel2022-64) then reinstall using the same method you attempted last time.
Launch maya
Hope this helps, just ran into and solved the same thing.
