I have create a layered texture by combing four files and placing one next to the other. Now I want to be able to repeat the texture I have created using the layered texture node. Does anybody know how to do this. You help would be greatly appreciated.
I have attached two images one showing the layered texture node in the Hypershade window and the other showing how I want the texture to be repeated Example_of_repeating_pattern
Hypershade_Files combined_to_create_layered_texture
Hi!
Well, then use an VRay equivalent (if available) or use A).
You can of course also bake (render) the texture to one new texture file.
