Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
MAYA REPEAT A LAYERED TEXTURE
3 REPLIES 3
796 Views, 3 Replies
I have create a layered texture by combing four files and placing one next to the other. Now I want to be able to repeat the texture I have created using the layered texture node. Does anybody know how to do this. You help would be greatly appreciated.
I have attached two images one showing the layered texture node in the Hypershade window and the other showing how I want the texture to be repeated Example_of_repeating_patternExample_of_repeating_patternHypershade_Files combined_to_create_layered_textureHypershade_Files combined_to_create_layered_texture
3 REPLIES 3
mspeer
mspeer
Hi!
A) Scale the UVs in UV Editor, or
B) add an aiUvTransform after the layeredTexture node.
Hi!
I am using Vray not Arnold so the aiUvTransform node is not available
mspeer
mspeer
Hi!
Well, then use an VRay equivalent (if available) or use A).
You can of course also bake (render) the texture to one new texture file.
Hi!
