I have create a layered texture by combing four files and placing one next to the other. Now I want to be able to repeat the texture I have created using the layered texture node. Does anybody know how to do this. You help would be greatly appreciated.
I have attached two images one showing the layered texture node in the Hypershade window and the other showing how I want the texture to be repeated
Hi!
Well, then use an VRay equivalent (if available) or use A).
You can of course also bake (render) the texture to one new texture file.
