Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya Bonus Tools 2020 error
3 REPLIES 3
g2m.agent
1019 Views, 3 Replies
  1. Stack / Align Objects cant change World Axis:
  2. Offset Transforms get error:
    Error: "C:/ProgramData/Autodesk/ApplicationPlugins/MayaBonusTools-2017-2020/Contents/scripts-2020/bt_offsetTransforms.mel" line 443.51: Unterminated string.
Tags (1)
3 REPLIES 3
in reply to: g2m.agent
I have the same error/issue... have you found a solution yet?
Me too. Can't change the World Axis, which is a shame as this could be a useful tool.
dracoliss
Hello.  I had this problem also.  I found the cause and a workaround.
It is because in the scripts, the variable "bt_moveSpace" may not yet be set or exported.
Once you open the Bonus Tool windows called "Modify > Offset Transforms..." and close it again, the "bt_moveSpace" variable is exported, and the axis starts to work again in "Modify > Stack / Align Objects..."
When this problem was posted I guess the script for Offset Transforms was also broken.  I am using the tools version released a few days ago that is also compatible with Maya 2022, so perhaps Offset Transforms is now fixed, and means you can now also fix Stack / Align yourself...
Technology Administrators
