Solved by dracoliss. Go to Solution.
I have the same error/issue... have you found a solution yet?
Hello. I had this problem also. I found the cause and a workaround.
It is because in the scripts, the variable "bt_moveSpace" may not yet be set or exported.
Once you open the Bonus Tool windows called "Modify > Offset Transforms..." and close it again, the "bt_moveSpace" variable is exported, and the axis starts to work again in "Modify > Stack / Align Objects..."
When this problem was posted I guess the script for Offset Transforms was also broken. I am using the tools version released a few days ago that is also compatible with Maya 2022, so perhaps Offset Transforms is now fixed, and means you can now also fix Stack / Align yourself...
