Announcements
pivot can't move in any direction
pablo.valladares.r
pablo.valladares.r
Hi friends, actually I was has a problem when I selected one object in the viewport and I want to move with pivot in another direction, the option Move appear like blocked and show the broken line box  instead moving object , its like the selection options its cause conflict in the some mode, I was try to change and reset al configurations inside Maya, I was try to change some peripherals and try to install Maya again and nothing happened, could help me with this problem, I have two students with the same problem.
mspeer
Hi!
1. Update your GPU driver.
2. Preferences > Display > Viewport 2.0 > Render Engine (set to "DirectX11").
pablo.valladares.r
The problem was fixed without problem.
