Maya 2022 lists a litany of errors and then has a fatal error and crashes every time I try to open it on my Mac. The recent update made it actually say "fatal error," where before it would just list errors and crash.
Would you have a stack trace of the crash ? To help identify the incompatibility being triggered
an Autodesk CER report number
or
an Apple crash report
Hi, the error report # is 309642220 and I'm attaching the crash file.
Thanks for your help
The crash looks to be related to startup initialization, possibly with new App Home display
you can disable App home to see if it makes a difference
Hi thanks, but how can I disable the app home without Maya opening? Seems like I need to be able to go into the preferences but I can't because it crashes.
Figured out how to set the env variable as a file in the preferences but it did not fix my issue. Any other suggestions? thanks
