Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2022 fatal error crash on open
7 REPLIES 7
Message 1 of 8
jmollot
1756 Views, 7 Replies
Maya 2022 lists a litany of errors and then has a fatal error and crashes every time I try to open it on my Mac. The recent update made it actually say "fatal error," where before it would just list errors and crash.
Labels (3)
7 REPLIES 7
Message 2 of 8
warnold1
in reply to: jmollot
Would you have a stack trace of the crash ? To help identify the incompatibility being triggered
an Autodesk CER report number
or
an Apple crash report
Wayne Arnold
Developer
Message 3 of 8
jmollot
in reply to: warnold1
Hi, the error report # is 309642220 and I'm attaching the crash file.
Thanks for your help
Message 4 of 8
warnold1
The crash looks to be related to startup initialization, possibly with new App Home display
you can disable App home to see if it makes a difference
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Maya-Bas...
Wayne Arnold
Developer
Message 5 of 8
jmollot
Hi thanks, but how can I disable the app home without Maya opening? Seems like I need to be able to go into the preferences but I can't because it crashes.
Message 6 of 8
jmollot
Figured out how to set the env variable as a file in the preferences but it did not fix my issue. Any other suggestions? thanks
Message 7 of 8
warnold1
Most likely the Maya.env file is parsed too late to be recognized
Would need to set before launching Maya
From a terminal window, set the environment variable then launch Maya from the terminal
(use the env var mentioned in the link) I don’t have access at the moment to look it up
export MAYA_…..=1
/Applications/Autodesk/maya2022/Maya.app/Contents/MacOS/Maya
Wayne Arnold
Developer
Message 8 of 8
jmollot
Thank you, so just type those two lines into terminal with the proper file path and env variable?
