Im using Maya 2018 student version and whenever i try to load anything, blank scenes, full scenes and new scenes the program will simply not load and instead display a fatal error message in the output box. i have tried numerous methods to solve this including performing a clean uninstall/reinstall, altering the system environment, adding it to my nvidia control panel and finally attempting to install new drivers. None of them worked and now im at a loss, any help would be appreciated. the attached image is a screencap of the error.
Solved by sean.heasley. Go to Solution.
Same problem here... I downgraded my driver version to the 382.33, and reset the maya prefs folder, without success...
BTW, my graphic card is a GeForce GTX 1060.
A friend has the exact same config (Razer Blade), and Maya is running fine with a more recent version of the NVidia drivers (388.73).
Initialized VP2.0 renderer {
Version : 2016.11.35.12. Feature Level 5.
Adapter : GeForce GTX 1060/PCIe/SSE2
Vendor ID: 4318. Device ID : 6427
Driver : .
API : OpenGL V.4.6.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 6144 MB.
CPU Memory Limit: 15462.4 MB.
OpenCL evaluator is attempting to initialize OpenCL.
Detected 2 OpenCL Platforms:
0: Intel(R) Corporation. Intel(R) OpenCL. OpenCL 2.0 .
Supported extensions: cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_fp64 cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_image2d_from_buffer cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_spir
1: Intel(R) Corporation. Intel(R) OpenCL. OpenCL 2.0 .
OpenCL evaluator failed to find OpenCL device with vendor NVIDIA Corporation.
Stack trace:
dxgi.dll!CompatString
dxgi.dll!CreateDXGIFactory2
dxgi.dll!DXGIGetDebugInterface1
nvoglv64.dll!DrvPresentBuffers
nvoglv64.dll!DrvValidateVersion
nvoglv64.dll!DllMain
nvoglv64.dll!DrvSwapLayerBuffers
KERNEL32.DLL!BaseThreadInitThunk
ntdll.dll!RtlUserThreadStart
Fatal Error. Attempting to save in C:/Users/PHILIP~1.EHR/AppData/Local/Temp/philippe.ehrhart.20180316.1112.ma
I have the same problem and tried the clean uninstall, running the application as administrator and launching maya from switch users. My Graphics card is also GeForce GTX 1060 and the error still persists...
Please help me rectify this issue!
Same here, Fatal Error, Attempting to save in C:/User/... etc. at the first student's installation.
When I lunch Maya the error's windows appears.
I have Gtx1080 driver 391.35
Windows 10 home
i7 7820hk
I need some URGENT help to install
Update:
I do a clean install of drivrer 388.43 downgrade from 391.35, still nothing.
I tryed to install 2018.2 pack, still nothing.
Hi @Anonymous
Did you try a clean uninstall/reinstall of Maya?
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
@sean.heasleywrote:Hi @Anonymous
Yes, but the problem remain the same.
Now I resetted my pc to defalt settings and try to reinstall as first programs.
Update:
Reset pc to factory settings;
Update GeForce Gtx1080 to 388.43 driver;
Launch as administrator Autodesk_Maya_2018_wi_en-US_setup_webinstall;
allow permission to pass Windows firewall;
launch Maya 2018 Students version and finally works.
Install Maya_2018_2_Update as administrator and works.
i have the same problem
finaly i fix it
my english is not very well
first
i have two video card
1.intel 630 on board
2.nvidia 1060
you can test input your vga or dvi cable into motherboard
and donot input any cable to video card
then put on power into windows
open maya
if maya can be open
you will find like this?
Hi @Anonymous
Glad you got it working! Thank you as well for posting the steps you took to fix it and marking them as the solution!
All the best,
Sean Heasley
i have a geforce gt 730 in my pc and maya keeps doign this : https://youtu.be/9CMs5OGSf1w is there a driver i can use to fix it the ge force drive first posted keeps coming up with can not find compatible hardware/ software when i try install it.
note:
i have tried clean uninstall and reinstall multiple times
i have tried running it in admin mode (( although already on an admin account))
i have tried older versions of maya such as 2017 as well as 2018.
do you have any on board video card ? like intel 630?
if you have
you can try to input your video cable to the motherboard the open maya
Hi @sean.heasley,
I'm getting the same fatal error when I open Maya. This happens in both Maya 2017 & Maya 2018.
System Configuration:
OS - Windows 10 x64
Intel Core i3 - 7100 3.90 GHz
RAM 4 Gb
Graphics Card - GeForce GT 1030
I've installed latest graphics drivers for GT 1030 - version 391.35, but the error still comes.
See screenshot:
I also tried to search whether my card is certified by autodesk or not!
but I did not find my graphics card from this document:
https://knowledge.autodesk.com/sites/default/files/HardwareCertificationResults_Maya2018_v01a.pdf
I want to know, what is the solution to solve this fatal error?
Looking forward to your response.
Hi @Anonymous
Thanks for posting the video of your crash!
I saw that an Autodesk CER Error report popped up that you closed out of. When you get a chance, can you please fill out that form and let me know what the CER number is?
This will allow me to look up your crash in our log and I can try and narrow down your issue.
Hi @Anonymous
Your card isn't supported so it's possible that is why Maya won't launch on your machine. By chance are you getting the same error report seen in @Anonymous's video above? If so please fill out the report as well and let me know the CER number!
All the best,
Sean Heasley
Hi @sean.heasley,
Yes, I'm facing same problem as @Anonymous, Fatal error dialog comes as I open Maya.
I just purchased my graphic card GT 1030 before 2 days.
Before I purchase graphics card, I've go through this post:
https://www.quora.com/Is-a-GeForce-GT1030-enough-for-Maya-and-3D-Max
At this point, what should I do to get rid of this error! Very bad situation!
Hi @Anonymous
What I meant was are you seeing this error report?
If so please fill it out and let me know what the CER Number is.
If you aren't receiving that error there's a few things you may want to try.
You'll want to make sure the GPU drivers are up to date for your 1030 gpu.
Steps to update your drivers can be found here!
You also may want to perform a clean uninstall/reinstall of Maya.
Also, please make sure you install and run Maya as an admin.
Let me know if anything changes!
All the best,
Sean Heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
Hi @sean.heasley,
Thanks for the response.
I glad to inform that 'fatal error' problem is solved.
I performed following steps:
1) I formatted the OS which was Windows 10 x64,
2) Cleaned my hard drive & made new partitions in HDD with Command prompt -
https://youtu.be/6FaDCq6z_U0?list=PLW5y-yS9toS1DWr-uoHW0CPtCUVwKt7ql
3) I installed Windows 8.1 x64
4) Update latest drivers - 391.35
5) Then installed Maya 2017.
Now, Maya 2017 is running fine. And I see that all drivers of graphics card GT 1030 are up to date.
Thank you for support.
Nikunj
Hi @sean.heasley,
I needed to clean entire HDD, bcoz I was getting error - 'windows cannot be installed to this disk the selected disk is of the gpt partition style'. so I thought to clean up everything on HDD.
But it may possible for other users that just format just C drive where current OS installed, and give a try for installing Windows 7/8/8.1 OS.
Replacing OS to windows 7/8/8.1 can be the fix to this fatal error.
Nikunj
