Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
how can i make the water wheel move along with a particle?
45 REPLIES 45
Message 1 of 46
1990 Views, 45 Replies
i made a water wheel with a particle and want the water wheel to be moving under the particle. i need a nconstraint but i wonder which one. do i use transform?
45 REPLIES 45
Message 41 of 46
in reply to: mspeer
im not sure if ive to only constraint transform the vertices to the emitter to make it move.
Message 42 of 46
haha I've another problem with a different project
its about my water wheel 😕 if you could go through this with me, the same way you did with the dominos, that would be so great! lol
Message 43 of 46
sean.heasley
sean.heasley
Hi @Anonymous
I'm making a video explaining how @Roland.Reyer and @mspeer have set up the scene and what they are trying to explain to you.
That said, in the meantime I made a quick video that is kinda of a workaround for your current set up. The wheel won't spin because of the particles however it will give the illusion that it is.
Please let me know if this helps or if you need any more assistance!
Hi @Anonymous
Message 44 of 46
in reply to: sean.heasley
thank you so much!!
i decided to change the emitter but now it kinda doesnt fall down XD i even have a gravity on the emitter
thank you so much!!
Message 45 of 46
how can i make the emitter go straight down?
Message 46 of 46
sean.heasley
sean.heasley
You would need to tweak the emitter settings/placement,
