Announcements
UV Unfold not working in 2017, 2018, but does work in 2015
javor_alex
javor_alex
I have the Unfold 3d plugin loaded and have tried reloading to no avail.
Whenever I unfold a set of UV's in 2017 or 2018, I get random, bizarre results. If I make the same cuts and unfold in 2015, I get what you would predict.
I've had issues with Unfold before in 2018 -- but that was because the Unfold3d plugin was not enabled by default. Once enabled, things worked as expected.
Now my issues seem beyond what I have been able to find via search or troubleshoot on my own. I can just do the work in 2015, but I am not very familiar with the interface in that version and would prefer to get things working with 2018.
Any help is appreciated.
20152015e76bb2f29d10648744603cd7264d9e1b
2018
Replies (7)
javor_alex
Some additional information.
I have ran mesh cleanup and thoroughly inspected the model for anything abnormal.
Sometimes I get unfold's that result in UV's exploding and going everywhere, but I also get this perfect circle unfold as well, despite where I place my cuts.
0c5533a497a91d6d8cd0161544e9c8bd
javor_alex
A little more information:
I did an automatic mapping, which broke the head mesh into like 6 different pieces, and in that case the unfold seemed to work as expected. But of course, that is not how I need to unfold my head mesh. The way I am working is by starting with a planar projection from the Z direction, and then just cutting the usual lines along the back of the head, cheek folds, chin, etc.
javor_alex
After 4 hours of troubleshooting with zero results, I think I'm just done with UV layout in Maya. I'm going to look at other apps.
mspeer
Hi!
Not sure if this will help:
https://forums.autodesk.com/t5/maya-modeling/maya-2017-unfold-not-rescaling-uvs-for-consistent-texel...
For further help please upload a scene-file (just before using Unfold).
javor_alex
I'll come back to this and get a scene file ready. But I ended up using the UVlayout app so I could keep progressing with my work.
I'd like to get things working in 2018 because i really like the relative ease of use compared to other versions, and I like doing most of my work in a single program as well, but I've got to wait a while because too much troubleshooting gets me all pissy.
sean.heasley
Hi @javor_alex
Sorry for the delayed response!
When you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
Let me know if anything changes!
sean.heasley
Hi @javor_alex
I'm just checking in again to see if you need more help with this. Do you still need assistance with this?
