i made a water wheel with a particle and want the water wheel to be moving under the particle. i need a nconstraint but i wonder which one. do i use transform?
Solved by sean.heasley. Go to Solution.
im not sure if ive to only constraint transform the vertices to the emitter to make it move.
haha I've another problem with a different project
its about my water wheel 😕 if you could go through this with me, the same way you did with the dominos, that would be so great! lol
Hi @Anonymous
I'm making a video explaining how @Roland.Reyer and @mspeer have set up the scene and what they are trying to explain to you.
That said, in the meantime I made a quick video that is kinda of a workaround for your current set up. The wheel won't spin because of the particles however it will give the illusion that it is.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
thank you so much!!
i decided to change the emitter but now it kinda doesnt fall down XD i even have a gravity on the emitter
You would need to tweak the emitter settings/placement,
All the best,
Sean Heasley
