Hi @Anonymous
The video you linked is unavailable, can you please link a working one?
A quick test you can try is deleting your settings/preferences then launch Maya and try to move the object.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
I fix my video i tried your mentioned solution but doesn't work
Thanks for your response
Hi @Anonymous
If you double click on the move tool and hit reset does that help?
Also, what GPU are you using and does the driver version match with our certified hardware list?
You can find our certified hardware list here!
All the best,
Sean Heasley
Hi @Anonymous
Glad you're up and running! Thanks for providing the solution @Anonymous !
All the best,
Sean Heasley
