Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Help:move tool doesn't move object by axis maya 2018
11 REPLIES 11
Message 1 of 12
6305 Views, 11 Replies
why i can't select axis and move object by it when select move tool??
Tags (4)
11 REPLIES 11
Message 2 of 12
sean.heasley
Hi @Anonymous
The video you linked is unavailable, can you please link a working one?
A quick test you can try is deleting your settings/preferences then launch Maya and try to move the object.
Message 3 of 12
in reply to: sean.heasley
I fix my video i tried your mentioned solution but doesn't work
Thanks for your response
Message 4 of 12
sean.heasley
Hi @Anonymous
If you double click on the move tool and hit reset does that help?
Also, what GPU are you using and does the driver version match with our certified hardware list?
You can find our certified hardware list here!
Message 5 of 12
Hi
It is an know issue change your openGl mode to legacy or compatibility I don't remember which one but It should fix your issue
Message 6 of 12
i change "viewport" to "DirectX 11" and then restart it's work
Message 7 of 12
Message 8 of 12
sean.heasley
Hi @Anonymous
Glad you're up and running! Thanks for providing the solution @Anonymous !
Message 9 of 12
With pleasure, as long as I can help to the extent of my knowledge.
Message 10 of 12
Message 11 of 12
Message 12 of 12
Technology Administrators
