Help:move tool doesn't move object by axis maya 2018
why i can't select axis and move object by it when select move tool??
Replies (11)
sean.heasley
Hi @Anonymous
The video you linked is unavailable, can you please link a working one?
A quick test you can try is deleting your settings/preferences then launch Maya and try to move the object.
I fix my video i tried your mentioned solution but doesn't work
Thanks for your response
sean.heasley
Hi @Anonymous
If you double click on the move tool and hit reset does that help?
Also, what GPU are you using and does the driver version match with our certified hardware list?
You can find our certified hardware list here!
Hi
It is an know issue change your openGl mode to legacy or compatibility I don't remember which one but It should fix your issue
i change "viewport" to "DirectX 11" and then restart it's work
sean.heasley
Hi @Anonymous
Glad you're up and running! Thanks for providing the solution @Anonymous !
With pleasure, as long as I can help to the extent of my knowledge.
