Hey I was wondering has anyone seen this in Maya 2016. I am modelling a Messerschmitt and I am using the duplicate special so I can mirror my sculpt. Every time I open my file I'm getting these green faces in Random places on my model. I was using the stock lambert shader before this happened then I applied a new lambert to fix the problem and now it is back. What does not make sense is that it is only on the instanced side of my model. I am chalking this up to a bug but if its something else I would love if someone could let me know what it is. Cheers.
Maya 2017 sp4
1 - Delete history - not working
2 - Apply new material - not working
3 - Delete -set new UV - not working
4 - Combine with other mesh and separate - not working
5 - reload maya - not working
6 - duplicate polygons - not working
What`s going on? 2017 ver and this bug near 10 years not resolve.
ty guys. So a corrupted shader? A new material fixed it, so I am guessing this was the correct diagnosis? Anyways, it fixed my random green object. So tyvm. Sorry for the bump ... but .... well it's fixed now and I am happy.. so ty.
Thanks for the tip. I had the same issue, just assigned the default lambert material and then re-applied my textured blinn material and all is well with the virtual world.
Hi!
@Anonymous
that's a different issue, you set a live surface:
https://help.autodesk.com/view/MAYAUL/2018/ENU/?guid=GUID-EBF1E652-4DDD-423F-B42E-3BF85AE46A5D
I know this has been solved. But I have something to add that might help someone in a situation I was just in.
I just had an outwardly identical situation caused by a completely different scenario and easy to solve when you know why it happens. I had some objects referenced in my scene in the past. At some point I removed the reference and imported the object directly. But by chance I had the exact same material (as I was having issue with) in a different reference that I have kept using. So when I imported the objects, it assigned the matching material to the referenced one. I didn't realise this. So while working I turned off (hid) my references in the references manage (not removed; unticked them). I didn't realise I had an issue because I also by change hid the group containing the object that were using that material. But later made that group visible again and they were that vibrant green. I was not able to clear the surface and reapply as I have done in the past and as mentioned in the topic.
After reading this I got a hunch to turn on my references and all the materials loaded. Makes sense but was a gotcha regardless. Would have been nice to not have the material match up with the reference automatically. I guess it useful to do so if you are using a reference set of materials. But it seems a referenced material applied is unlink-able when the reference is not presently loaded. At least I wasn't able to find a way to unlink.
-Thanks for your time.
using the trial of Maya 2020 and this bug still exists. I am with Maya since v1.0 and it is obvious that Maya still has a problem deep down in the core of creating geometry / keeping geometry clean. 10 years ago it was much harder than today, but still the software is not working stable in this manner and to say it clearly: No one has the motivation to change it. It is like it is with most politicians: You can ignore it or talk nicely about the topic and do nothing -> people will still follow you / buy your stuff.
This time I am a bit more angry than normal, because a simple 5min task now (again) became to a work of some hours and still nothing works, even the re-import as OBJ (is there a single one out there who has ever finished a professional project without using the OBJ-export-import script at least once during the project duration??).
It’s hard to pin point why sometimes things don’t work for other users, and sometimes is definitely a bug that has been detected.
I have not yet encountered these issues in the above posts during production... keeping my fingers crossed.
Happy holidays guys .
In maya 2019 (not sure if you can do this in other versions) you can save the file (maybe with a different name just in case glitch doesn't disappear) and then open a new file. Once new file is open, reopen the saved file with the green polygons. Once the "glitched" file is open green polygons should have disappeared. Hope that helps.
Ad bashing: unfortunately, there are times when kicking the beehive is the only way to get action. Do you know Revit? Have you ever used its stairs tool? Have you ever cut stringers out of a wet 20' 2X12? If the answer is yes to any, do a search for revit stairs. See how far they date back. Still not fixed. I would think, if you were offered a job at one of the world's largest software companies you should have thicker skin to criticism. Just sayin. Autodesk is great! Huge fan. Perfect? No. Does it warrent suggesting they have "special needs" level intelligence? No, but, he is more entitled to voice his opinion, than people are from being offended by that opinion. Remember sticks and stones?
I to was having the green face problem. Solved it with a aistandard surface.
Hello to all
To solve this problem, you can use the Advanced Skelton script
Seems to be a shader issue. I had it happened when bridging edges on a model. The new faces were all green, but after selecting the object (Object Mode) and assigning a material it went back to normal. I just assigned the standard lambert material and it was fixed
