Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Error on FBX export.
3 REPLIES 3
f_a_montalvo12
171 Views, 3 Replies
My FBX export in not appearing on my Plug in manager. It happened to me a couple of weeks ago, and I followed all the procedure of deleting my settings and preferences but it didn't work. I had to delete the whole program and re install it again. After a couple of weeks of working fine today it did the same thing to me. I retry to resetting my preferences and settings following the Autodesk support guide on how to do it, but still not working. I don't want to keep uninstalling and installing Maya every time this happens.. what else can I do ?Screenshot 2024-06-26 at 11.49.22 AM.png
3 REPLIES 3
brentmc
in reply to: f_a_montalvo12
The plug-in is part of the Maya app bundle so I have no idea how that could be deleted?!
I've asked around internally to see if anyone is aware of this issue...
Thanks.
Brent McPherson
Principle Engineer
syracoj
It's because your Maya.app isn't under /Applications/Autodesk/yourMayaVersion
I just moved my /Applications/Autodesk/maya2025/Maya.app to /Applications/Maya.app
launched maya via Maya.app and I can no longer find the fbx plugin.
When Maya installs on OSX it should be creating a directory under applications. For instance, on my OSX machine for my 2025 install I have
/Applications/Autodesk/maya2025 and the Maya.app should be under here (the maya2025 directory).
If need be, try creating this directory hierarchy by hand and put the Maya.app in there and launch Maya.
I can see in your attached image that your Maya.app (see the red error bar in the script history) is under Applications.
f_a_montalvo12
in reply to: syracoj
I appreciate this recommendation, I had a job for Sunday and I was freaking out. Thanks a lot, it helped doing that and now I know how to fix it in the future.
Technology Administrators
