Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Can't open Render Setup window
22 REPLIES 22
Message 1 of 23
ljadick
10555 Views, 22 Replies
Hi there,
I have a rig I'm referencing into multiple scenes.  As soon as it's referenced in, I'm unable to open the Render Setup window.
Error: line 1: AttributeError: file C:\Program Files\Autodesk\Maya2018\Python\lib\site-packages\maya\app\renderSetup\model\renderSetup.py line 422: 'RenderSetup' object has no attribute '_defaultRenderLayer' //
I can open the render setup window and then open the scene file and the window remains, but that's not really a long-term solution.
I have't made any changes to the window (no layers, overrides, etc).
I have no trouble opening the render setup window in the rig file.
If I import the rig, sometimes I'm only able to open the Render Setup window about half the time.
I tried resetting my preferences but that didn't solve the issue.  This happens on multiple machines, so a fresh install isn't the solution either.
I'd appreciate any ideas.  I'm a bit at a loss at the moment.
Thanks!
-Lauren
22 REPLIES 22
Message 21 of 23
info
in reply to: ljadick
I got the same issue, anyone from Autodesk has a clear solution?
Message 22 of 23
ebomke
4 Years with no official Autodesk support for something that is a brick wall in your path.
Message 23 of 23
ayushbakshi98
So I guess we are gonna make anniversary of such issues... In 2023, same issue in 2022.4 (supposed to be stable) Maya.
Good Job Autodesk!
Technology Administrators
