Hi there,
I have a rig I'm referencing into multiple scenes. As soon as it's referenced in, I'm unable to open the Render Setup window.
Error: line 1: AttributeError: file C:\Program Files\Autodesk\Maya2018\Python\lib\site-packages\maya\app\renderSetup\model\renderSetup.py line 422: 'RenderSetup' object has no attribute '_defaultRenderLayer' //
I can open the render setup window and then open the scene file and the window remains, but that's not really a long-term solution.
I have't made any changes to the window (no layers, overrides, etc).
I have no trouble opening the render setup window in the rig file.
If I import the rig, sometimes I'm only able to open the Render Setup window about half the time.
I tried resetting my preferences but that didn't solve the issue. This happens on multiple machines, so a fresh install isn't the solution either.
I'd appreciate any ideas. I'm a bit at a loss at the moment.
Thanks!
-Lauren
Solved by ljadick. Go to Solution.
So I guess we are gonna make anniversary of such issues... In 2023, same issue in 2022.4 (supposed to be stable) Maya.
Good Job Autodesk!
