Black Screen problem in Maya 2019
I seem to have the problem of having a stripped screen that won't let me see or even work on Maya 2019. I can click on tools but I can't see anything with the screen blocking everything. I've tried to delete the program to reinstall it twice and it still came up with the same screen. When I first installed in January it was working but since last week this issue started to appear. Can someone help me with this issue?
sean.heasley
Hi @Anonymous
This is most likely a GPU issue. What GPU are you using and is the driver version the same as our certified hardware list?
You can find our certified hardware list here!
A quick test you can try as well is deleting your settings/preferences.
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided on Friday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
