- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm currently having a problem that I can't find a fix to in the internet.
I have Maya 2017 installed and want to use the rendering software Solid Angle Arnold. I downloaded the newest version of Arnold and installed it.
When I open up Maya, it tells me the following:
Warning: file: F:/Program Files/Autodesk/Maya2017/scripts/others/supportRenderers.mel line 64: The renderer "arnold" used by this scene, is not currently available. The "mayaSoftware" renderer will be used instead. //
If I try to manually load mtoa in the plugin manager, it fails with the following error:
// Error: line 1: Unable to dynamically load : C:/solidangle/mtoadeploy/2017/plug-ins/mtoa.mll
A DLL initialization routine has failed.
My CPU supports SSE4.2 according to coreinfo.exe. It is an AMD Phenom X4 955 processor.
I have tried everything like deleting the pymel.log and whatever.
Can someone help me?
