Arnold Renderer - DLL Initialization Routine failed
Message 1 of 15
I'm currently having a problem that I can't find a fix to in the internet.
I have Maya 2017 installed and want to use the rendering software Solid Angle Arnold. I downloaded the newest version of Arnold and installed it.
When I open up Maya, it tells me the following:
Warning: file: F:/Program Files/Autodesk/Maya2017/scripts/others/supportRenderers.mel line 64: The renderer "arnold" used by this scene, is not currently available. The "mayaSoftware" renderer will be used instead. //
If I try to manually load mtoa in the plugin manager, it fails with the following error:
// Error: line 1: Unable to dynamically load : C:/solidangle/mtoadeploy/2017/plug-ins/mtoa.mll
A DLL initialization routine has failed.
My CPU supports SSE4.2 according to coreinfo.exe. It is an AMD Phenom X4 955 processor.
I have tried everything like deleting the pymel.log and whatever.
Can someone help me?
Replies (14)
Message 2 of 15
sean.heasley
Hi @Anonymous and welcome to the community!
Good on you for checking about SSE4.2 thats usually a common issue.
You can check this link as well for other potential solutions.
Let me know if they work!
Message 3 of 15
EDIT:
I got Dependency Walker to work. A whole lot of DLLs are missing.
I don't know how to log it so Im just posting a screenshot...
And also second screen that my CPU supports SSE 4.2
Message 4 of 15
sean.heasley
Okay in that case you can check microsofts website and download the DLLs you are missing and see if that changes anything.
Message 5 of 15
I downloaded the Microsoft VS Redistributable 2017 package that didn't change anything.
But its not just these here is the entire list:
API-MS-WIN-CORE-APIQUERY-L1-1-0.DLL
API-MS-WIN-CORE-APPCOMPAT-L1-1-1.DLL
API-MS-WIN-CORE-APPINIT-L1-1-0.DLL
API-MS-WIN-CORE-ATOMS-L1-1-0.DLL
API-MS-WIN-CORE-COM-L1-1-0
API-MS-WIN-CORE-COM-L1-1-1.DLL
API-MS-WIN-CORE-COM-MIDLPROXYSTUB-L1-1-0.DLL
API-MS-WIN-CORE-COM-PRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-COM-PRIVATE-L1-1-1.DLL
API-MS-WIN-CORE-COMM-L1-1-0.DLL
API-MS-WIN-CORE-CONSOLE-L1-1-0.DLL
API-MS-WIN-CORE-CONSOLE-L2-1-0.DLL
API-MS-WIN-CORE-CRT-L1-1-0.DLL
API-MS-WIN-CORE-CRT-L2-1-0.DLL
API-MS-WIN-CORE-DATETIME-L1-1-1.DLL
API-MS-WIN-CORE-DATETIME-L1-1-2.DLL
API-MS-WIN-CORE-DEBUG-L1-1-0.DLL
API-MS-WIN-CORE-DEBUG-L1-1-1.DLL
API-MS-WIN-CORE-DELAYLOAD-L1-1-0.DLL
API-MS-WIN-CORE-DELAYLOAD-L1-1-1.DLL
API-MS-WIN-CORE-ENCLAVE-L1-1-0.DLL
API-MS-WIN-CORE-ERRORHANDLING-L1-1-0.DLL
API-MS-WIN-CORE-ERRORHANDLING-L1-1-1.DLL
API-MS-WIN-CORE-ERRORHANDLING-L1-1-3.DLL
API-MS-WIN-CORE-FIBERS-L1-1-1.DLL
API-MS-WIN-CORE-FIBERS-L2-1-1.DLL
API-MS-WIN-CORE-FILE-L1-1-0.DLL
API-MS-WIN-CORE-FILE-L1-2-0.DLL
API-MS-WIN-CORE-FILE-L1-2-1.DLL
API-MS-WIN-CORE-FILE-L1-2-2.DLL
API-MS-WIN-CORE-FILE-L2-1-0.DLL
API-MS-WIN-CORE-FILE-L2-1-1.DLL
API-MS-WIN-CORE-FILE-L2-1-2.DLL
API-MS-WIN-CORE-HANDLE-L1-1-0.DLL
API-MS-WIN-CORE-HEAP-L1-1-0.DLL
API-MS-WIN-CORE-HEAP-L1-2-0.DLL
API-MS-WIN-CORE-HEAP-L2-1-0.DLL
API-MS-WIN-CORE-HEAP-OBSOLETE-L1-1-0.DLL
API-MS-WIN-CORE-INTERLOCKED-L1-1-0.DLL
API-MS-WIN-CORE-INTERLOCKED-L1-2-0.DLL
API-MS-WIN-CORE-IO-L1-1-0.DLL
API-MS-WIN-CORE-IO-L1-1-1.DLL
API-MS-WIN-CORE-JOB-L1-1-0.DLL
API-MS-WIN-CORE-JOB-L2-1-0.DLL
API-MS-WIN-CORE-KERNEL32-LEGACY-L1-1-1.DLL
API-MS-WIN-CORE-KERNEL32-LEGACY-L1-1-5.DLL
API-MS-WIN-CORE-KERNEL32-PRIVATE-L1-1-1.DLL
API-MS-WIN-CORE-KERNEL32-PRIVATE-L1-1-2.DLL
API-MS-WIN-CORE-LARGEINTEGER-L1-1-0.DLL
API-MS-WIN-CORE-LIBRARYLOADER-L1-1-0.DLL
API-MS-WIN-CORE-LIBRARYLOADER-L1-2-0.DLL
API-MS-WIN-CORE-LIBRARYLOADER-L1-2-2.DLL
API-MS-WIN-CORE-LIBRARYLOADER-L2-1-0.DLL
API-MS-WIN-CORE-LOCALIZATION-L1-1-0.DLL
API-MS-WIN-CORE-LOCALIZATION-L1-2-0.DLL
API-MS-WIN-CORE-LOCALIZATION-L1-2-1.DLL
API-MS-WIN-CORE-LOCALIZATION-L1-2-2.DLL
API-MS-WIN-CORE-LOCALIZATION-L2-1-0.DLL
API-MS-WIN-CORE-LOCALIZATION-OBSOLETE-L1-3-0.DLL
API-MS-WIN-CORE-LOCALIZATION-PRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-LOCALREGISTRY-L1-1-0.DLL
API-MS-WIN-CORE-MEMORY-L1-1-0.DLL
API-MS-WIN-CORE-MEMORY-L1-1-2.DLL
API-MS-WIN-CORE-MISC-L1-1-0.DLL
API-MS-WIN-CORE-NAMEDPIPE-L1-2-0.DLL
API-MS-WIN-CORE-NAMEDPIPE-L1-2-2.DLL
API-MS-WIN-CORE-NAMESPACE-L1-1-0.DLL
API-MS-WIN-CORE-NORMALIZATION-L1-1-0.DLL
API-MS-WIN-CORE-PATH-L1-1-0.DLL
API-MS-WIN-CORE-PERFCOUNTERS-L1-1-0.DLL
API-MS-WIN-CORE-PRIVATEPROFILE-L1-1-1.DLL
API-MS-WIN-CORE-PROCESSENVIRONMENT-L1-1-0.DLL
API-MS-WIN-CORE-PROCESSENVIRONMENT-L1-2-0.DLL
API-MS-WIN-CORE-PROCESSSNAPSHOT-L1-1-0.DLL
API-MS-WIN-CORE-PROCESSTHREADS-L1-1-0.DLL
API-MS-WIN-CORE-PROCESSTHREADS-L1-1-1.DLL
API-MS-WIN-CORE-PROCESSTHREADS-L1-1-2.DLL
API-MS-WIN-CORE-PROCESSTHREADS-L1-1-3.DLL
API-MS-WIN-CORE-PROCESSTOPOLOGY-L1-2-0.DLL
API-MS-WIN-CORE-PROFILE-L1-1-0.DLL
API-MS-WIN-CORE-PSAPI-ANSI-L1-1-0.DLL
API-MS-WIN-CORE-PSAPI-L1-1-0.DLL
API-MS-WIN-CORE-PSAPI-OBSOLETE-L1-1-0.DLL
API-MS-WIN-CORE-PSM-KEY-L1-1-0.DLL
API-MS-WIN-CORE-QUIRKS-L1-1-0.DLL
API-MS-WIN-CORE-REALTIME-L1-1-0.DLL
API-MS-WIN-CORE-REGISTRY-L1-1-0.DLL
API-MS-WIN-CORE-REGISTRY-L1-1-1.DLL
API-MS-WIN-CORE-REGISTRY-L2-2-0.DLL
API-MS-WIN-CORE-REGISTRYUSERSPECIFIC-L1-1-0.DLL
API-MS-WIN-CORE-RTLSUPPORT-L1-1-0.DLL
API-MS-WIN-CORE-RTLSUPPORT-L1-2-0.DLL
API-MS-WIN-CORE-SHLWAPI-LEGACY-L1-1-0.DLL
API-MS-WIN-CORE-SHLWAPI-OBSOLETE-L1-2-0.DLL
API-MS-WIN-CORE-SIDEBYSIDE-L1-1-0.DLL
API-MS-WIN-CORE-STRING-L1-1-0.DLL
API-MS-WIN-CORE-STRING-L2-1-0.DLL
API-MS-WIN-CORE-STRING-L2-1-1.DLL
API-MS-WIN-CORE-STRING-OBSOLETE-L1-1-0.DLL
API-MS-WIN-CORE-STRINGANSI-L1-1-0.DLL
API-MS-WIN-CORE-SYNCH-L1-1-0.DLL
API-MS-WIN-CORE-SYNCH-L1-2-0.DLL
API-MS-WIN-CORE-SYNCH-L1-2-1.DLL
API-MS-WIN-CORE-SYSINFO-L1-1-0.DLL
API-MS-WIN-CORE-SYSINFO-L1-2-0.DLL
API-MS-WIN-CORE-SYSINFO-L1-2-1.DLL
API-MS-WIN-CORE-SYSINFO-L1-2-3.DLL
API-MS-WIN-CORE-THREADPOOL-L1-2-0.DLL
API-MS-WIN-CORE-THREADPOOL-LEGACY-L1-1-0.DLL
API-MS-WIN-CORE-THREADPOOL-PRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-TIMEZONE-L1-1-0.DLL
API-MS-WIN-CORE-URL-L1-1-0.DLL
API-MS-WIN-CORE-UTIL-L1-1-0.DLL
API-MS-WIN-CORE-VERSION-L1-1-0.DLL
API-MS-WIN-CORE-VERSION-L1-1-1.DLL
API-MS-WIN-CORE-VERSION-PRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-VERSIONANSI-L1-1-0.DLL
API-MS-WIN-CORE-VERSIONANSI-L1-1-1.DLL
API-MS-WIN-CORE-WINDOWSERRORREPORTING-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-ERROR-L1-1-1.DLL
API-MS-WIN-CORE-WINRT-STRING-L1-1-0.DLL
API-MS-WIN-CORE-WOW64-L1-1-0.DLL
API-MS-WIN-CORE-WOW64-L1-1-1.DLL
API-MS-WIN-CORE-XSTATE-L2-1-0.DLL
API-MS-WIN-CRT-CONVERT-L1-1-0.DLL
API-MS-WIN-CRT-ENVIRONMENT-L1-1-0.DLL
API-MS-WIN-CRT-FILESYSTEM-L1-1-0.DLL
API-MS-WIN-CRT-HEAP-L1-1-0.DLL
API-MS-WIN-CRT-LOCALE-L1-1-0.DLL
API-MS-WIN-CRT-MATH-L1-1-0.DLL
API-MS-WIN-CRT-MULTIBYTE-L1-1-0.DLL
API-MS-WIN-CRT-PRIVATE-L1-1-0.DLL
API-MS-WIN-CRT-RUNTIME-L1-1-0.DLL
API-MS-WIN-CRT-STDIO-L1-1-0.DLL
API-MS-WIN-CRT-STRING-L1-1-0.DLL
API-MS-WIN-CRT-TIME-L1-1-0.DLL
API-MS-WIN-CRT-UTILITY-L1-1-0.DLL
API-MS-WIN-DEVICES-CONFIG-L1-1-1.DLL
API-MS-WIN-EVENTING-CLASSICPROVIDER-L1-1-0.DLL
API-MS-WIN-EVENTING-CONSUMER-L1-1-0.DLL
API-MS-WIN-EVENTING-CONTROLLER-L1-1-0.DLL
API-MS-WIN-EVENTING-OBSOLETE-L1-1-0.DLL
API-MS-WIN-EVENTING-PROVIDER-L1-1-0.DLL
API-MS-WIN-GDI-DPIINFO-L1-1-0.DLL
API-MS-WIN-GDI-INTERNAL-UAP-L1-1-0.DLL
API-MS-WIN-MM-MISC-L1-1-1.DLL
API-MS-WIN-MM-MME-L1-1-0.DLL
API-MS-WIN-MM-TIME-L1-1-0.DLL
API-MS-WIN-SECURITY-ACTIVEDIRECTORYCLIENT-L1-1-0.DLL
API-MS-WIN-SECURITY-APPCONTAINER-L1-1-0.DLL
API-MS-WIN-SECURITY-AUDIT-L1-1-1.DLL
API-MS-WIN-SECURITY-BASE-L1-2-0.DLL
API-MS-WIN-SECURITY-BASE-PRIVATE-L1-1-1.DLL
API-MS-WIN-SECURITY-CAPABILITY-L1-1-0.DLL
API-MS-WIN-SECURITY-GROUPPOLICY-L1-1-0.DLL
API-MS-WIN-SECURITY-LSAPOLICY-L1-1-0.DLL
API-MS-WIN-SECURITY-SDDL-L1-1-0.DLL
API-MS-WIN-SERVICE-CORE-L1-1-1.DLL
API-MS-WIN-SERVICE-CORE-L1-1-2.DLL
API-MS-WIN-SERVICE-MANAGEMENT-L1-1-0.DLL
API-MS-WIN-SERVICE-MANAGEMENT-L2-1-0.DLL
API-MS-WIN-SERVICE-PRIVATE-L1-1-0
API-MS-WIN-SERVICE-PRIVATE-L1-1-1.DLL
API-MS-WIN-SERVICE-PRIVATE-L1-1-2.DLL
API-MS-WIN-SERVICE-WINSVC-L1-2-0.DLL
API-MS-WIN-SHCORE-SCALING-L1-1-1.DLL
API-MS-WIN-SHELL-SHELLCOM-L1-1-0.DLL
API-MS-WIN-SHELL-SHELLFOLDERS-L1-1-0.DLL
API-MS-WIN-STORAGE-EXPORTS-EXTERNAL-L1-1-0.DLL
API-MS-WIN-STORAGE-EXPORTS-INTERNAL-L1-1-0.DLL
API-MS-ONECOREUAP-SETTINGSYNC-STATUS-L1-1-0.DLL
API-MS-WIN-APPMODEL-IDENTITY-L1-2-0.DLL
API-MS-WIN-APPMODEL-RUNTIME-INTERNAL-L1-1-0.DLL
API-MS-WIN-APPMODEL-RUNTIME-INTERNAL-L1-1-3.DLL
API-MS-WIN-APPMODEL-RUNTIME-L1-1-0.DLL
API-MS-WIN-APPMODEL-RUNTIME-L1-1-1.DLL
API-MS-WIN-APPMODEL-RUNTIME-L1-1-2.DLL
API-MS-WIN-APPMODEL-STATE-L1-2-0.DLL
API-MS-WIN-APPMODEL-UNLOCK-L1-1-0.DLL
API-MS-WIN-BASE-UTIL-L1-1-0.DLL
API-MS-WIN-CORE-CALENDAR-L1-1-0.DLL
API-MS-WIN-CORE-COM-L1-1-0.DLL
API-MS-WIN-CORE-COM-L2-1-1.DLL
API-MS-WIN-CORE-DATETIME-L1-1-0.DLL
API-MS-WIN-CORE-FIRMWARE-L1-1-0.DLL
API-MS-WIN-CORE-KERNEL32-LEGACY-L1-1-0.DLL
API-MS-WIN-CORE-LOCALIZATION-OBSOLETE-L1-2-0.DLL
API-MS-WIN-CORE-MARSHAL-L1-1-0.DLL
API-MS-WIN-CORE-MEMORY-L1-1-1.DLL
API-MS-WIN-CORE-MEMORY-L1-1-4.DLL
API-MS-WIN-CORE-PRIVATEPROFILE-L1-1-0.DLL
API-MS-WIN-CORE-PROCESSTOPOLOGY-OBSOLETE-L1-1-0.DLL
API-MS-WIN-CORE-PSM-APPNOTIFY-L1-1-0.DLL
API-MS-WIN-CORE-REALTIME-L1-1-1.DLL
API-MS-WIN-CORE-REGISTRY-PRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-SHLWAPI-OBSOLETE-L1-1-0.DLL
API-MS-WIN-CORE-SHUTDOWN-L1-1-1.DLL
API-MS-WIN-CORE-TEXTINPUT-CLIENT-L1-1-0.DLL
API-MS-WIN-CORE-TOOLHELP-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-ERRORPRIVATE-L1-1-1.DLL
API-MS-WIN-CORE-WINRT-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-PROPERTYSETPRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-PROPERTYSETPRIVATE-L1-1-1.DLL
API-MS-WIN-CORE-WINRT-REGISTRATION-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-ROBUFFER-L1-1-0.DLL
API-MS-WIN-COREUI-SECRUNTIME-L1-1-0.DLL
API-MS-WIN-DEVICES-QUERY-L1-1-1.DLL
API-MS-WIN-DOWNLEVEL-ADVAPI32-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-ADVAPI32-L2-1-0.DLL
API-MS-WIN-DOWNLEVEL-KERNEL32-L2-1-0.DLL
API-MS-WIN-DOWNLEVEL-NORMALIZ-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-OLE32-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-SHELL32-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-SHLWAPI-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-SHLWAPI-L2-1-0.DLL
API-MS-WIN-DOWNLEVEL-SHLWAPI-L2-1-1.DLL
API-MS-WIN-DOWNLEVEL-USER32-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-VERSION-L1-1-0.DLL
API-MS-WIN-DWMAPI-L1-1-0.DLL
API-MS-WIN-DX-D3DKMT-L1-1-0.DLL
API-MS-WIN-DX-D3DKMT-L1-1-2.DLL
API-MS-WIN-EVENTING-LEGACY-L1-1-0.DLL
API-MS-WIN-EVENTLOG-LEGACY-L1-1-0.DLL
API-MS-WIN-MM-JOYSTICK-L1-1-0.DLL
API-MS-WIN-MM-MISC-L2-1-0.DLL
API-MS-WIN-NTUSER-RECTANGLE-L1-1-0.DLL
API-MS-WIN-NTUSER-SYSPARAMS-L1-1-0.DLL
API-MS-WIN-OLE32-IE-L1-1-0.DLL
API-MS-WIN-POWER-BASE-L1-1-0.DLL
API-MS-WIN-POWER-SETTING-L1-1-0.DLL
API-MS-WIN-RO-TYPERESOLUTION-L1-1-0.DLL
API-MS-WIN-RTCORE-NTUSER-CLIPBOARD-L1-1-0.DLL
API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-0.DLL
API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-1.DLL
API-MS-WIN-RTCORE-NTUSER-SYNCH-L1-1-0.DLL
API-MS-WIN-RTCORE-NTUSER-WINDOW-L1-1-0.DLL
API-MS-WIN-RTCORE-NTUSER-WINEVENT-L1-1-0.DLL
API-MS-WIN-SECURITY-ACCESSHLPR-L1-1-0.DLL
API-MS-WIN-SECURITY-ACTIVEDIRECTORYCLIENT-L1-1-1.DLL
API-MS-WIN-SECURITY-BASE-L1-1-0.DLL
API-MS-WIN-SECURITY-CREDENTIALS-L1-1-0.DLL
API-MS-WIN-SECURITY-CREDENTIALS-L2-1-0.DLL
API-MS-WIN-SECURITY-CRYPTOAPI-L1-1-0.DLL
API-MS-WIN-SECURITY-LSALOOKUP-L1-1-1.DLL
API-MS-WIN-SECURITY-LSALOOKUP-L1-1-2.DLL
API-MS-WIN-SECURITY-LSALOOKUP-L2-1-1.DLL
API-MS-WIN-SECURITY-PROVIDER-L1-1-0.DLL
API-MS-WIN-SECURITY-SDDLPARSECOND-L1-1-0.DLL
API-MS-WIN-SECURITY-SYSTEMFUNCTIONS-L1-1-0.DLL
API-MS-WIN-SERVICE-WINSVC-L1-1-0.DLL
API-MS-WIN-SHCORE-COMHELPERS-L1-1-0.DLL
API-MS-WIN-SHCORE-OBSOLETE-L1-1-0.DLL
API-MS-WIN-SHCORE-REGISTRY-L1-1-1.DLL
API-MS-WIN-SHCORE-STREAM-L1-1-0.DLL
API-MS-WIN-SHCORE-STREAM-WINRT-L1-1-0.DLL
API-MS-WIN-SHCORE-SYSINFO-L1-1-0.DLL
API-MS-WIN-SHCORE-THREAD-L1-1-0.DLL
API-MS-WIN-SHCORE-UNICODEANSI-L1-1-0.DLL
API-MS-WIN-SHLWAPI-IE-L1-1-0.DLL
API-MS-WIN-SHLWAPI-WINRT-STORAGE-L1-1-1.DLL
CLMINT.DLL
DEVICELOCKHELPERS.DLL
EMCLIENT.DLL
EXT-MS-MF-PAL-L2-1-0.DLL
EXT-MS-ONECORE-APPCHROMEAPI-L1-1-0.DLL
EXT-MS-ONECORE-APPDEFAULTS-L1-1-0.DLL
EXT-MS-ONECORE-APPMODEL-VEVENTDISPATCHER-L1-1-0.DLL
EXT-MS-ONECORE-DCOMP-L1-1-0.DLL
EXT-MS-ONECORE-HLINK-L1-1-0.DLL
EXT-MS-ONECORE-ORIENTATION-L1-1-0.DLL
EXT-MS-ONECORE-PHONEINFO-L1-1-0.DLL
EXT-MS-ONECORE-SHELLCHROMEAPI-L1-1-1.DLL
EXT-MS-ONECORE-SHELLCHROMEAPI-L1-1-2.DLL
EXT-MS-WIN-ADVAPI32-MSI-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-NPUSERNAME-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-NTMARTA-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-PSM-APP-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-REGISTRY-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-SAFER-L1-1-0.DLL
EXT-MS-WIN-APPCOMPAT-APPHELP-L1-1-0.DLL
EXT-MS-WIN-APPMODEL-DAXCORE-L1-1-0.DLL
EXT-MS-WIN-APPMODEL-DEPLOYMENT-L1-1-1.DLL
EXT-MS-WIN-APPMODEL-STATE-EXT-L1-2-0.DLL
EXT-MS-WIN-APPMODEL-USERCONTEXT-L1-1-0.DLL
EXT-MS-WIN-APPMODEL-VIEWSCALEFACTOR-L1-1-0.DLL
EXT-MS-WIN-APPXDEPLOYMENTCLIENT-APPXDEPLOY-L1-1-0.DLL
EXT-MS-WIN-APPXDEPLOYMENTCLIENT-APPXDEPLOYONECORE-L1-1-0.DLL
EXT-MS-WIN-AUDIOCORE-PAL-L1-1-2.DLL
EXT-MS-WIN-AUTHZ-CONTEXT-L1-1-0.DLL
EXT-MS-WIN-AUTHZ-REMOTE-L1-1-0.DLL
EXT-MS-WIN-COM-CLBCATQ-L1-1-0.DLL
EXT-MS-WIN-COM-COML2-L1-1-1.DLL
EXT-MS-WIN-COM-OLE32-L1-1-1.DLL
EXT-MS-WIN-COM-OLE32-L1-1-4.DLL
EXT-MS-WIN-COM-PSMREGISTER-L1-2-1.DLL
EXT-MS-WIN-COM-SUSPENDRESILIENCY-L1-1-0.DLL
EXT-MS-WIN-CORE-WINRT-REMOTE-L1-1-0.DLL
EXT-MS-WIN-DEVMGMT-DM-L1-1-0.DLL
EXT-MS-WIN-DEVMGMT-POLICY-L1-1-0.DLL
EXT-MS-WIN-DIRECT2D-DESKTOP-L1-1-0.DLL
EXT-MS-WIN-DOMAINJOIN-NETJOIN-L1-1-0.DLL
EXT-MS-WIN-DWMAPIDXGI-EXT-L1-1-0.DLL
EXT-MS-WIN-EDPUTIL-POLICY-L1-1-0.DLL
EXT-MS-WIN-EVENTING-RUNDOWN-L1-1-0.DLL
EXT-MS-WIN-FAMILYSAFETY-CHILDACCOUNT-L1-1-0.DLL
EXT-MS-WIN-FECLIENT-ENCRYPTEDFILE-L1-1-0.DLL
EXT-MS-WIN-FIREWALLAPI-WEBPROXY-L1-1-0.DLL
EXT-MS-WIN-GDI-CLIPPING-L1-1-0.DLL
EXT-MS-WIN-GDI-DC-CREATE-L1-1-1.DLL
EXT-MS-WIN-GDI-DC-L1-2-0.DLL
EXT-MS-WIN-GDI-DC-L1-2-1.DLL
EXT-MS-WIN-GDI-DEVCAPS-L1-1-0.DLL
EXT-MS-WIN-GDI-DRAW-L1-1-1.DLL
EXT-MS-WIN-GDI-DRAW-L1-1-3.DLL
EXT-MS-WIN-GDI-FONT-L1-1-1.DLL
EXT-MS-WIN-GDI-FONT-L1-1-3.DLL
EXT-MS-WIN-GDI-INTERNAL-DESKTOP-L1-1-0.DLL
EXT-MS-WIN-GDI-METAFILE-L1-1-1.DLL
EXT-MS-WIN-GDI-METAFILE-L1-1-2.DLL
EXT-MS-WIN-GDI-PATH-L1-1-0.DLL
EXT-MS-WIN-GDI-PRINT-L1-1-0.DLL
EXT-MS-WIN-GDI-PRIVATE-L1-1-0.DLL
EXT-MS-WIN-GDI-RENDER-L1-1-0.DLL
EXT-MS-WIN-GDI-WCS-L1-1-0.DLL
EXT-MS-WIN-GPAPI-GROUPPOLICY-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-APPCOMPAT-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-DATETIME-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-ERRORHANDLING-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-FILE-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-LOCALIZATION-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-PACKAGE-CURRENT-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-PACKAGE-L1-1-1.DLL
EXT-MS-WIN-KERNEL32-QUIRKS-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-QUIRKS-L1-1-1.DLL
EXT-MS-WIN-KERNEL32-REGISTRY-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-SIDEBYSIDE-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-WINDOWSERRORREPORTING-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-WINDOWSERRORREPORTING-L1-1-1.DLL
EXT-MS-WIN-KERNELBASE-PROCESSTHREAD-L1-1-0.DLL
EXT-MS-WIN-MININPUT-INPUTHOST-L1-1-0.DLL
EXT-MS-WIN-MPR-MULTIPLEPROVIDERROUTER-L1-1-0.DLL
EXT-MS-WIN-MRMCORER-ENVIRONMENT-L1-1-0.DLL
EXT-MS-WIN-MRMCORER-RESMANAGER-L1-1-0.DLL
EXT-MS-WIN-NTDSAPI-ACTIVEDIRECTORYCLIENT-L1-1-0.DLL
EXT-MS-WIN-NTDSAPI-ACTIVEDIRECTORYCLIENT-L1-1-1.DLL
EXT-MS-WIN-NTUSER-DC-ACCESS-EXT-L1-1-0.DLL
EXT-MS-WIN-NTUSER-DIALOGBOX-L1-1-1.DLL
EXT-MS-WIN-NTUSER-DRAW-L1-1-1.DLL
EXT-MS-WIN-NTUSER-DRAW-L1-1-2.DLL
EXT-MS-WIN-NTUSER-GUI-L1-3-0.DLL
EXT-MS-WIN-NTUSER-KEYBOARD-L1-1-1.DLL
EXT-MS-WIN-NTUSER-KEYBOARD-L1-3-0.DLL
EXT-MS-WIN-NTUSER-MENU-L1-1-2.DLL
EXT-MS-WIN-NTUSER-MESSAGE-L1-1-1.DLL
EXT-MS-WIN-NTUSER-MESSAGE-L1-1-3.DLL
EXT-MS-WIN-NTUSER-MISC-L1-3-0.DLL
EXT-MS-WIN-NTUSER-MISC-L1-5-1.DLL
EXT-MS-WIN-NTUSER-MOUSE-L1-1-0.DLL
EXT-MS-WIN-NTUSER-PRIVATE-L1-2-0.DLL
EXT-MS-WIN-NTUSER-PRIVATE-L1-3-1.DLL
EXT-MS-WIN-NTUSER-RECTANGLE-EXT-L1-1-0.DLL
EXT-MS-WIN-NTUSER-ROTATIONMANAGER-L1-1-0.DLL
EXT-MS-WIN-NTUSER-SERVER-L1-1-0.DLL
EXT-MS-WIN-NTUSER-STRING-L1-1-0.DLL
EXT-MS-WIN-NTUSER-SYNCH-L1-1-0.DLL
EXT-MS-WIN-NTUSER-UICONTEXT-EXT-L1-1-0.DLL
EXT-MS-WIN-NTUSER-WINDOW-L1-1-1.DLL
EXT-MS-WIN-NTUSER-WINDOW-L1-1-3.DLL
EXT-MS-WIN-NTUSER-WINDOW-L1-1-4.DLL
EXT-MS-WIN-NTUSER-WINDOWCLASS-L1-1-1.DLL
EXT-MS-WIN-NTUSER-WINDOWSTATION-L1-1-1.DLL
EXT-MS-WIN-OLE32-BINDCTX-L1-1-0.DLL
EXT-MS-WIN-OLE32-IE-EXT-L1-1-0.DLL
EXT-MS-WIN-OLE32-OLEAUTOMATION-L1-1-0.DLL
EXT-MS-WIN-PROFILE-EXTENDER-L1-1-0.DLL
EXT-MS-WIN-PROFILE-LOAD-L1-1-0.DLL
EXT-MS-WIN-PROFILE-USERENV-L1-1-0.DLL
EXT-MS-WIN-PROFILE-USERENV-L1-1-1.DLL
EXT-MS-WIN-RAS-RASAPI32-L1-1-0.DLL
EXT-MS-WIN-RDR-DAVHLPR-L1-1-0.DLL
EXT-MS-WIN-RO-TYPERESOLUTION-L1-1-0.DLL
EXT-MS-WIN-ROMETADATA-DISPENSER-L1-1-0.DLL
EXT-MS-WIN-RPC-SSL-L1-1-0.DLL
EXT-MS-WIN-RTCORE-GDI-DEVCAPS-L1-1-0.DLL
EXT-MS-WIN-RTCORE-GDI-OBJECT-L1-1-0.DLL
EXT-MS-WIN-RTCORE-GDI-RGN-L1-1-0.DLL
EXT-MS-WIN-RTCORE-GDI-RGN-L1-1-1.DLL
EXT-MS-WIN-RTCORE-MINUSER-INPUT-L1-1-2.DLL
EXT-MS-WIN-RTCORE-MINUSER-PRIVATE-EXT-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-CURSOR-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-DC-ACCESS-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-DPI-L1-2-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-IAM-L1-1-1.DLL
EXT-MS-WIN-RTCORE-NTUSER-INTEGRATION-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-SYNCH-EXT-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-SYSCOLORS-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-SYSPARAMS-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-WINDOW-EXT-L1-1-0.DLL
EXT-MS-WIN-SECUR32-TRANSLATENAME-L1-1-0.DLL
EXT-MS-WIN-SECURITY-CAPAUTHZ-L1-1-0.DLL
EXT-MS-WIN-SECURITY-CHAMBERS-L1-1-0.DLL
EXT-MS-WIN-SECURITY-CREDUI-INTERNAL-L1-1-0.DLL
EXT-MS-WIN-SECURITY-CREDUI-L1-1-0.DLL
EXT-MS-WIN-SECURITY-CRYPTUI-L1-1-0.DLL
EXT-MS-WIN-SECURITY-CRYPTUI-L1-1-1.DLL
EXT-MS-WIN-SECURITY-EFS-L1-1-0.DLL
EXT-MS-WIN-SECURITY-EFSWRT-L1-1-1.DLL
EXT-MS-WIN-SESSION-USERMGR-L1-1-0.DLL
EXT-MS-WIN-SESSION-USERTOKEN-L1-1-0.DLL
EXT-MS-WIN-SESSION-WINSTA-L1-1-0.DLL
EXT-MS-WIN-SESSION-WTSAPI32-L1-1-0.DLL
EXT-MS-WIN-SETUPAPI-INF-L1-1-0.DLL
EXT-MS-WIN-SETUPAPI-INF-L1-1-1.DLL
EXT-MS-WIN-SHELL-DIRECTORY-L1-1-0.DLL
EXT-MS-WIN-SHELL-EMBEDDEDMODE-L1-1-0.DLL
EXT-MS-WIN-SHELL-PROPSYS-L1-1-0.DLL
EXT-MS-WIN-SHELL-SHELL32-L1-2-0.DLL
EXT-MS-WIN-SHELL-SHLWAPI-L1-1-0.DLL
EXT-MS-WIN-SHELL32-SHELLCOM-L1-1-0.DLL
EXT-MS-WIN-SMBSHARE-BROWSERCLIENT-L1-1-0.DLL
EXT-MS-WIN-STORAGE-SENSE-L1-1-0.DLL
EXT-MS-WIN-SXS-OLEAUTOMATION-L1-1-0.DLL
EXT-MS-WIN-UI-VIEWMANAGEMENT-L1-1-0.DLL
EXT-MS-WIN-USP10-L1-1-0.DLL
EXT-MS-WIN-WER-UI-L1-1-0.DLL
EXT-MS-WIN-WER-XBOX-L1-1-0.DLL
EXT-MS-WIN-WINRT-STORAGE-L1-1-0.DLL
EXT-MS-WIN-WLAN-ONEXUI-L1-1-0.DLL
EXT-MS-WIN-WWAN-WWAPI-L1-1-0.DLL
EXT-MS-WIN-WWAN-WWAPI-L1-1-1.DLL
IESHIMS.DLL
LIBPPIAPI-C-1.2.DLL
MGMDFMODEL-2_0.DLL
MGMDFPARSER-2_0.DLL
OGSARCHIVE-16.DLL
SHCORE.DLL
SHLWAPI.DLL
TBB.DLL
IEFRAME.DLL
3DGRAPHICS.DLL
ADSKASSETBROWSERLIB.DLL
ADVAPI32.DLL
AG.DLL
AI.DLL
AI_RENDERVIEW.DLL
ANIMENGINE.DLL
ANIMSLICE.DLL
ANIMUISLICE.DLL
APPVERSION.DLL
AUTOCAM.DLL
AVIFIL32.DLL
AWCACHESHARED.DLL
AWGR.DLL
AWMARKINGMENUS.DLL
AWNSOLVER.DLL
BASE.DLL
BCRYPT.DLL
BCRYPTPRIMITIVES.DLL
CLEW.DLL
CLMLOADER.DLL
COMBASE.DLL
COMCTL32.DLL
COMDLG32.DLL
COMMANDENGINE.DLL
CRYPT32.DLL
D3D9.DLL
D3DCOMPILER_46.DLL
DATAMODEL.DLL
DBGCORE.DLL
DBGHELP.DLL
DCIMAN32.DLL
DDRAW.DLL
DEFORMSLICE.DLL
DEPENDCOMMAND.DLL
DEPENDENGINE.DLL
DNSAPI.DLL
DPAPI.DLL
DWMAPI.DLL
DYNSLICE.DLL
DYNUISLICE.DLL
EXPLORERSLICE.DLL
EXTENSIONLAYER.DLL
FBXASSETSCORE2.DLL
FOUNDATION.DLL
GDI32.DLL
GEOMETRYALG.DLL
GEOMETRYDEFN.DLL
GEOMETRYENGINE.DLL
GESTURA.DLL
GLEW.DLL
GLU32.DLL
HWDIRECTX.DLL
HWFOUNDATION.DLL
HWGL.DLL
HWRENDER.DLL
HWRENDERMAYA.DLL
ICUDT53.DLL
ICUIN53.DLL
ICUUC53.DLL
IFF.DLL
IMAGE.DLL
IMAGEUI.DLL
IMFBASE.DLL
IMM32.DLL
IPHLPAPI.DLL
KERNEL32.DLL
KERNELBASE.DLL
KINSLICE.DLL
LIBAWXML2.DLL
LIBIOMP5MD.DLL
LIBMMD.DLL
MANIPS.DLL
MC3.DLL
METADATA.DLL
MFC110U.DLL
MODELSLICE.DLL
MODELUISLICE.DLL
MODIFIERS.DLL
MPR.DLL
MSACM32.DLL
MSASN1.DLL
MSI.DLL
MSVCP110.DLL
MSVCP140.DLL
MSVCP_WIN.DLL
MSVCR110.DLL
MSVCRT.DLL
MSVFW32.DLL
MSWSOCK.DLL
MTOA.MLL
MTOA_API.DLL
NORMALIZ.DLL
NSI.DLL
NTDLL.DLL
NURBS.DLL
NURBSENGINE.DLL
NURBSSLICE.DLL
OGSATILINTEGRATION-16.DLL
OGSDEVICES-16.DLL
OGSGRAPHICS-16.DLL
OGSMAYABRIDGE.DLL
OGSOBJECTS-16.DLL
OGSRENDER.DLL
OLE32.DLL
OLEAUT32.DLL
OPENAL32.DLL
OPENCLUTILITIES.DLL
OPENGL32.DLL
OPENMAYA.DLL
OPENMAYAANIM.DLL
OPENMAYAFX.DLL
OPENMAYARENDER.DLL
OPENMAYAUI.DLL
PCRE.DLL
POLY.DLL
POLYENGINE.DLL
POLYSLICE.DLL
PSAPI.DLL
PTEX.DLL
PYTHON27.DLL
QT5CORE.DLL
QT5GUI.DLL
QT5MULTIMEDIA.DLL
QT5MULTIMEDIAWIDGETS.DLL
QT5NETWORK.DLL
QT5OPENGL.DLL
QT5POSITIONING.DLL
QT5PRINTSUPPORT.DLL
QT5QML.DLL
QT5QUICK.DLL
QT5SENSORS.DLL
QT5SQL.DLL
QT5SVG.DLL
QT5WEBCHANNEL.DLL
QT5WEBKIT.DLL
QT5WEBKITWIDGETS.DLL
QT5WIDGETS.DLL
RENDERMODEL.DLL
RENDERSLICE.DLL
RPCRT4.DLL
SECHOST.DLL
SECUR32.DLL
SHARED.DLL
SHAREDUI.DLL
SHELL32.DLL
SSPICLI.DLL
SUBDIV.DLL
SUBDIVENGINE.DLL
SUBDIVGEOM.DLL
SVML_DISPMD.DLL
SYNCOLOR.2017.0.69.DLL
SYNCOLOR.DLL
SYNHUB.DLL
TBBMALLOC.DLL
TESSELATION.DLL
TRANSLATORS.DLL
URCHINSLICE.DLL
USER32.DLL
UXTHEME.DLL
VCOMP110.DLL
VCRUNTIME140.DLL
VERSION.DLL
VNN.DLL
WEIGHTXML.DLL
WIN32U.DLL
WINMM.DLL
WINMMBASE.DLL
WINSPOOL.DRV
WINTRUST.DLL
WLDAP32.DLL
WRAPPERWACOM.DLL
WS2_32.DLL
WSOCK32.DLL
ACLUI.DLL
ACTIVEDS.DLL
ADP_CORE-6_1.DLL
ADP_DATA-6_1.DLL
ADP_SERVICE_OPCZIP-6_1.DLL
ADP_TOOLKIT-6_1.DLL
ADSLDPC.DLL
ADVPACK.DLL
AEPIC.DLL
APPHELP.DLL
AUTHZ.DLL
AVRT.DLL
BCP47LANGS.DLL
BROWCLI.DLL
CABINET.DLL
CERTCA.DLL
CFGMGR32.DLL
CHAKRA.DLL
CHARTV.DLL
COMCTL32.DLL
COML2.DLL
COMPPKGSUP.DLL
CONCRT140.DLL
COREMESSAGING.DLL
COREUICOMPONENTS.DLL
CREDUI.DLL
CRYPTBASE.DLL
CRYPTNET.DLL
CRYPTNGC.DLL
CRYPTSP.DLL
CRYPTUI.DLL
CSCAPI.DLL
D2D1.DLL
D3D11.DLL
DAVHLPR.DLL
DCOMP.DLL
DEVMGR.DLL
DEVOBJ.DLL
DEVRTL.DLL
DFSCLI.DLL
DHCPCSVC.DLL
DHCPCSVC6.DLL
DMCMNUTILS.DLL
DMPUSHPROXY.DLL
DRVSTORE.DLL
DSPARSE.DLL
DSREG.DLL
DSROLE.DLL
DUI70.DLL
DUSER.DLL
DWRITE.DLL
DXGI.DLL
EAPPCFG.DLL
EAPPPRXY.DLL
EDPUTIL.DLL
EFSADU.DLL
EFSCORE.DLL
EFSUTIL.DLL
EFSWRT.DLL
ELSCORE.DLL
ESENT.DLL
FECLIENT.DLL
FIREWALLAPI.DLL
FLTLIB.DLL
FMS.DLL
FWBASE.DLL
FWPOLICYIOMGR.DLL
GDIPLUS.DLL
IEADVPACK.DLL
IEAPFLTR.DLL
IERTUTIL.DLL
IEUI.DLL
IMAGEHLP.DLL
IMGUTIL.DLL
INETCOMM.DLL
IRI.DLL
LIBPPIAPI-CPP.DLL
LINKINFO.DLL
LOGONCLI.DLL
MFC42U.DLL
MFPLAT.DLL
MGSTYLIZATION-16.DLL
MI.DLL
MIUTILS.DLL
MLANG.DLL
MMDEVAPI.DLL
MPRMSG.DLL
MRMCORER.DLL
MSCTF.DLL
MSFEEDS.DLL
MSHTML.DLL
MSILTCFG.DLL
MSIMG32.DLL
MSLS31.DLL
MSOERT2.DLL
MSVCP110_WIN.DLL
NCAAPI.DLL
NCRYPT.DLL
NETAPI32.DLL
NETUTILS.DLL
NEWDEV.DLL
NTASN1.DLL
NTDSAPI.DLL
NTSHRUI.DLL
OCCACHE.DLL
ODBC32.DLL
OLEACC.DLL
OLEDLG.DLL
OMADMAPI.DLL
ONEX.DLL
POLICYMANAGER.DLL
POWRPROF.DLL
PRINTUI.DLL
PRNTVPT.DLL
PROFAPI.DLL
PROPSYS.DLL
PUIAPI.DLL
RASAPI32.DLL
RASMAN.DLL
REGAPI.DLL
RSTRTMGR.DLL
RTUTILS.DLL
RTWORKQ.DLL
SAMCLI.DLL
SAMLIB.DLL
SCECLI.DLL
SETUPAPI.DLL
SHDOCVW.DLL
SLC.DLL
SPFILEQ.DLL
SPINF.DLL
SPPC.DLL
SRPAPI.DLL
SRVCLI.DLL
TAPI32.DLL
TBS.DLL
TPMCOREPROVISIONING.DLL
TWINAPI.APPCORE.DLL
TWINAPI.DLL
UIAUTOMATIONCORE.DLL
URLMON.DLL
USERENV.DLL
VAULTCLI.DLL
VIRTDISK.DLL
W32TOPL.DLL
WDSCORE.DLL
WEBIO.DLL
WEBSERVICES.DLL
WEBSOCKET.DLL
WER.DLL
WEVTAPI.DLL
WINBRAND.DLL
WINDOWSCODECS.DLL
WINHTTP.DLL
WININET.DLL
WINNSI.DLL
WINSCARD.DLL
WINSTA.DLL
WKSCLI.DLL
WLANAPI.DLL
WMICLNT.DLL
WPAXHOLDER.DLL
WPCWEBFILTER.DLL
WRAPPERPPI.DLL
WRAPPERWMPOINTER.DLL
WTSAPI32.DLL
XMLLITE.DLL
Message 6 of 15
I just checked a few of the missing DLLs in this list, and they actually are in the system32 folder. They are just not being loaded.
What can I do to solve this problem?
Message 7 of 15
sean.heasley
Ok lets try these steps
  1.  Make sure Maya is up to date (currently Update 4).
  2. Download & Install the latest version of Arnold (MtoA) from Solid Angle. Click here for download page
  3. Reset your Maya preferences folder. Follow this guide.
  4. Start Maya
  5. Windows > Settings/Preferences > Plugin manager > and make sure that mtoa.mll is checked as Loaded and Auto Load.agasg.png
Message 8 of 15
1. There is no version number on the about maya tab, Im using student version though. Maybe that's part of the problem?
2. Already did that.
3. Didn't work.
5. Error still occurs.
Message 9 of 15
I have reinstalled the student version now to make sure it is the newest one, and no change.
I really don't know what to do and I need Arnold for my project in university. Help?
One of my colleagues is by the way experiencing the same issue.
Message 10 of 15
Stephen.Blair
You get the Maya version from Help > About Maya
Or by running
about -iv
about -c
Upload your depends dwi file.
// Stephen Blair
// Arnold Renderer Support
Message 11 of 15
Results:
about -iv;
// Autodesk Maya 2017 //
about -c;
// 201606150345-997974 //
As I said I'm using the Student version so if this is not the newest version I'm not sure how to update it.
DWI file couldn't be attached so I used an external file hoster.
 https://www.file-upload.net/download-12575581/mtoa.dwi.html
Message 12 of 15
Stephen.Blair
There's way too many DLLs missing, which made me wonder about your processor.
Everything I see for AMD Phenom X4 955 says that it doesn't support SSE4.1
Can you post your coreinfo output (the lines for SSE support) ?
// Stephen Blair
Message 13 of 15
I already did but I can post again.
And it's actually AMD Phenom II X4 955 Processor. Maybe its different for that one because CoreInfo says it is supported, at least that is how I interpret it?
Message 14 of 15
Stephen.Blair
A dash means not supported
I'm sorry, but that processor doesn't support SSE4.1, and you won't be able to use Arnold on that machine.
// Stephen Blair
Message 15 of 15
Okay so my first idea was actually right, but I misread the program's output 😕 I thought that what is listed is supported.
Thnks for the help though, I will have to find a computer in the university to realize my project then.
